Offline shiju
#1 Posted : 28 April 2017 22:08:04(UTC)
shiju
India
Smath is not properly working on my new windows 10 laptop.
While loading the Smath program, the loading image suddenly goes smaller and then open the program.
But the side panel is not visible, and the work space height is loaded in smaller than the screen height.
When clicking the restore button near the close button at top corner, the side panel appears back.
The screen response to the mouse and the keys are slow.
Defining a variable is looking like not responding the program.
Can anybody help me....
Shiju
#2 Posted : 28 April 2017 22:38:26(UTC)
please check if you have the image region plugin installed and in this case remove it
Offline shiju
#3 Posted : 29 April 2017 11:26:40(UTC)
shiju
India
Thanks Carpi, It works now.
Bye the bye, why is it so?
Shiju
Edited by moderator 02 October 2017 21:32:53(UTC)  | Reason: Not specified
#4 Posted : 29 April 2017 12:13:50(UTC)
Good Good
it's currently under investigation, but since I'm not able to reproduce on my Win10 it's a little bit tricky to find the cause... Umnik
Edited by user 16 November 2017 21:31:20(UTC)  | Reason: fixed
Offline beto0387
#5 Posted : 31 October 2017 07:29:05(UTC)
beto0387
Nicaragua
Shiju
Hi Shiju!
How did you fix it? I have the same problem on my laptop which it's running Windows 10. I don't know if it has to do with any display setting or with the Windows version. I was getting started with Smath two months ago but I had to stop the learning process a few days after starting. Now, I'm beginning again and I face the same problem.
I would really appreciate any help on this topic.
P.S. Excuse me for my English, it is not very good
Offline shiju
#6 Posted : 31 October 2017 07:37:00(UTC)
shiju
India
Hi
I removed the image region plugin. Then Smath is working fine now. Try this.
Shiju
Offline beto0387
#7 Posted : 03 November 2017 19:28:54(UTC)
beto0387
Nicaragua
Hi Shiju!
Thanks!! I removed the image region plugin and it's working now.
Guest (2)
