SMath Studio Forum
Download SMath Studio
Archive
Stable: SMath Studio 0.99.6622 (17 February 2018)
They talk about us
A great and essential application for scientists and engineers. The updates are regular and it has plugins that make it complete and as powerful as the paid applications.
more...
by Yibbou
I've used this software for several years and can not use anything else for work. I'm a mechanical Engineer and use this for any calculations I do.
1) To show and check my work
2) to set values and write descriptions so I can reuse my formulas for other projects.
This is better than any calculator.
Thank you Smath for such a great software.
more...
by Shawn Paul
- Desktop (Linux):
- [BUL] Bulgarian / Български
- [CAT] Catalan / Català
- [CZE] Czech / Čeština
- [DAN] Danish / Dansk
- [DUT] Dutch / Nederlands
- [ENG] English / English
- [FAS] Persian / فارسی
- [FIN] Finnish / Suomi
- [FRE] French / Français
- [GER] German / Deutsch
- [GRE] Greek / Ελληνικά
- [HEB] Hebrew / עברית
- [HUN] Hungarian / Magyar
- [ITA] Italian / Italiano
- [JPN] Japanese / 日本語
- [KOR] Korean / 한국어
- [LAV] Latvian / Latviešu
- [LTH] Lithuanian / Lietuvių
- [NOR] Norwegian / Norsk
- [POL] Polish / Polski
- [RON] Romanian / Română
- [RUS] Russian / Русский
- [SCR] Croatian / Hrvatski
- [SLK] Slovak / Slovenčina
- [SPA] Spanish / Español
- [SWE] Swedish / Svenska
- [TUR] Turkish / Türkçe
Introduction of the use of SMath Studio by Gilberto E. Urroz, Ph.D., P.E. Other files SMath Studio icons ( ) of all available sizes (16x16, 24x24, 32x32, 48x48, 64x64, 96x96, 128x128, 256x256) in PNG format.
on 17/02/2018(UTC), on 17/02/2018(UTC), on 17/02/2018(UTC), on 17/02/2018(UTC), on 17/02/2018(UTC), on 17/02/2018(UTC), on 17/02/2018(UTC), on 18/02/2018(UTC), on 20/02/2018(UTC), on 03/03/2018(UTC)
SMath Studio in the Cloud updated to use SMath Core 0.99.6622. Both features: equations breaking and inserting special symbols into equations - are now supported in Cloud.
Almost forgot to highlight the following important change done in this release: errors_behavior_1.sm (5kb) downloaded 47 time(s).Best regards.
on 19/02/2018(UTC), on 20/02/2018(UTC), on 20/02/2018(UTC)
Hi Andrey Very surprised that an error popped up in the latest build. Maybe also the one before, not sure. For your info, here is the S' definition It seems that somehow these last two builds cannot find a value of the matrix coordinates indicated. It worked fine in .6484 from October, which I have gone back to. I can send you the file, but I would prefer to do so privately. Love this program Doug Schickler
Hello. Originally Posted by: dschick Very surprised that an error popped up in the latest build. Maybe also the one before, not sure. Please send a worksheet to me so I could reproduce and fix this issue. E-mail is specifield into About dialog of SMath Studio. Thank you for the report!
Originally Posted by: dschick It seems that somehow these last two builds cannot find a value of the matrix coordinates indicated.It worked fine in .6484 from October, which I have gone back to.I can send you the file, but I would prefer to do so privately. That it worked 6484, I doubt as it shows incorrectly dressed. If you had a result => most probably erroneous. On the setup "rotation*matrix", Smath [4356, 6179] displays an error message. The rule Matrix*Rotation is universal, not commutative. UnknownConfidential.sm (203kb) downloaded 41 time(s). Rotate Breather [4 Orientations].sm (1,002kb) downloaded 41 time(s).
I have noticed that if I open a .sm file which has file properties set to "read only", the program will crash if I press the "save" button. It would be nice if it instead prompted to "save-as" in that scenario, or just notify the user that the file is read only so the user can then perform a save-as instead. This is on Windows 7. Thanks.
Originally Posted by: RickH I have noticed that if I open a .sm file which has file properties set to "read only", the program will crash if I press the "save" button. It would be nice if it instead prompted to "save-as" in that scenario, or just notify the user that the file is read only so the user can then perform a save-as instead. This is on Windows 7. Thanks. Already fixed in SS 0.98.6626 and later nightly builds, will be part of next stable release. Edited by user 03 April 2018 12:15:36(UTC)
SMath Studio Forum
Archive
