I think I need a program loop to get the graph to show up correctly. Suggestions? Quick Sound Loss.smz (133kb) downloaded 47 time(s).Edited by user 13 April 2018 08:19:33(UTC)
Originally Posted by: ElSid I think I need a program loop to get the graph to show up correctly.Suggestions? "Why does log10 look different ?" because you have two different formulas, thus two different results
Jean, The second equation is off/not evaluated. Graphically log to base x and log10 display differently. Question is about graph though
Strict math seems correct to me; let's compare the values for different directivity factors at ssame distance. we have: to simplify things we can get rid of the absolute value; in your example all numbers are above 1, plus logarithms' arguments are <= 8 in numerator and >= 12 in denominator (4*pi*distance_greater_than_1), thus: Code:|10*log10(a/b)| = 10*(log10(b)-log10(a)) = 10*(log10(f(x))-log10(Q)) = 10*log10(f(x))-10*log10(Q)
at same distance, log10(f(x)) is the same for every directivity factor Q Code:10*log10(f(x))-10*log10(Q) = const-10*log10(Q)
10*log10(2)=3, 10*log10(4)=6, 10*log10(8)=9 (approx)
Lp(Q,x)=Lw(Q,1.5)-|10*log10(a/b)|=Lw(Q,1.5)-const+10*log10(Q)
Lw(Q,1.5) loses -3dB when you double Q, but at the same time the absolute value term adds +3B -> so why values are so close (and functions overlapped in the plot) In fact, if you go further, you can do the same for Lw: Code:Lw(Q,dist) = Ltot+|10*log10(Q/f(dist))| = Ltot+10*log10(f(dist))-10*log10(Q) = const2-10*log10(Q)
Lp(Q,x) = Lw(Q,1.5)-const1+10*log10(Q) = const2-10*log10(Q)-const1+10*log10(Q) = const2-const1 = constant
and decimal shown in the workshet are only because different decimal places shown in the results Edited by user 10 April 2018 22:17:02(UTC)
| Reason: typo |
What might be wrong... You have sound pressure measured by the vendor -> You have to calculate the power level for the distance and directivity condition of the vendorThen you have the sound power level of your source... it's a constant! Use this value to estimate the sound power at various distances for various directivity conditions! Quick Sound Loss - rev.1.sm (135kb) downloaded 41 time(s).Edited by user 10 April 2018 20:53:37(UTC)
Davide, I did the same thing, where I assumed directivity is b=2 on Lw. I'll just document that and move on as the rest of the math appears to work out
Originally Posted by: ElSid Jean, The second equation is off/not evaluated.Graphically log to base x and log10 display differently.Question is about graph though Few more things you can do as real project. Line style "splines" is a bit smoother in the low region. Quick Sound Loss - rev.2.sm (135kb) downloaded 35 time(s).
Funny ... OK, here I am as I had done most of the items that Davide and Jean added. Now I would like to add a "dot" or a vertical line where the dB.final is. Please use this sheet Quick Sound Loss.smz (136kb) downloaded 34 time(s).Jean, I did not see where you used a spline All should I be using "cinterp" to place the "dot? Edited by user 10 April 2018 23:45:56(UTC)
| Reason: Added question
Originally Posted by: ElSid Jean, I did not see where you used a spline
All should I be using "cinterp" to place the "dot? 1. spline is for line style ... line/spline. 2. what that gyzma #,#,#,,,does in maths ? 3. X_Y plot does not support " in your plot suggestion 4. X_Y is for final/final/final ... project once done, if you rework something above=> it will freak the plot X_Y plot has slightly pregnant memory. Doctored in red . Quick Sound Loss (3).sm (141kb) downloaded 42 time(s).
Originally Posted by: CBG Something like this? Carlos, I think you attached the wrong file. Yes, that is what I was looking for. Jean, When I double click the graph on your latest file, my computer locks up. I'm on version 0.99.6671. NOW my file is locking up!!! ARRG Edited by user 11 April 2018 03:26:26(UTC)
| Reason: Jean file locks up
Originally Posted by: ElSid Jean, When I double click the graph on your latest file, my computer locks up.I'm on version 0.99.6671. My 6179 opens your 6671 ... your 6671 freezes opening 6179 Is it a bug ? BTW, attach an image of the polynomials that fail [as you reported].
Originally Posted by: Jean Giraud Few more things you can do as real project. Thanks Elsid, Nice project, saved for myself, you can have it as is. Jean Inst_dB Sound.sm (143kb) downloaded 33 time(s).
Well, Here we go again ... I found a quirk. Depending on values dB initial values, neither solve nor FindRoot is functional. I was plugging in values by hand without seeing an issue. I tried a "higher" dB set of values (86 vs 75) for equipment and the calculation *zap* Quick Sound Loss.smz (169kb) downloaded 32 time(s).Also, the X-Y plot legend information *ZAP* Edited by user 13 April 2018 09:45:39(UTC)
Originally Posted by: ElSid Well, Here we go again ... I found a quirk.Depending on values dB initial values, neither solve nor FindRoot is functional.I was plugging in values by hand without seeing an issue.I tried a "higher" dB set of values (86 vs 75) for equipment and the calculation *zap* That one was Doctored and you don't use the Doctored version. Explained before, if above X_Y something is Doctored, zap. Quick Sound Loss (4) Doctored 20180413.sm (168kb) downloaded 39 time(s).
Found the issue(s). See revamped file. Still having issues in that X-Y plot Labels for the legend *zap* Quick Sound Loss.smz (143kb) downloaded 61 time(s).Edit: Two bugs - X-Y Plot. If functions crash, *Zap* to the legend titles. All other titles OK. Legend is empty due to laziness after last 5 crashes
- solve(4) did not like trying to cancel units in the denominator of the final function (#dist). As I was adding units to x:0-100 FT and dividing the units meters in the function, the function crashed in the solve block (Just the function, with all values plugged in except for x = vector, so it's a solve(4) issue).
This is one of those sheets where UNITS are huge! The equations are all based off of SI/metric references. Major issue There is additional documentation and function definition updates. Sanity check the graph x scale (adjusted for feet since I'm in the US). Should be good now Edited by user 13 April 2018 20:37:55(UTC)
Originally Posted by: ElSid Found the issue.I'll post revamp file.Still having issues in that X-Y plot Labels for the legend *zap* Clik on "list", edit "series name".
Revisiting this old calc with SMath newer features and some function definitions. - No longer works if I redefine the logarithmic sum with vectorize
- I cannot get the "heat capacity function" to work for ploting
Sound Loss (Quick).sm (477kb) downloaded 15 time(s).Thanks for the help. Edited by user 26 January 2021 02:55:57(UTC)
| Reason: Added attachement
Joined: 28/08/2014(UTC) Posts: 1,370 Was thanked: 830 time(s) in 526 post(s)
Hi. Some notes, but I'm not sure if this solve all of the issues: 1. Use count inside rangeindividual, but not outside. You use it in f(x, b ), and guess that could be problematic. 2. After that, you divide x by 'm in f and x by feet in rangeindividual, choose only one. 3. Maybe here don't affect, but if rangeindividual have not f(#,#) as parameter, define f before rangeindividual, you know, just in case. Best regards. Alvaro.
