#1 Posted : 10 July 2014 20:38:20(UTC)
As for now, do not use this plugin for productivity Beta
Look in the attachment for details and features.
SMath Studio 0.97.5301 or later required
PLEASE REPORT HERE ANY ISSUE
Edited by user 11 July 2014 01:13:24(UTC)  | Reason: Not specified
File Attachment(s):
EEL_functions.sm (23kb) downloaded 391 time(s).
on 09/11/2022(UTC)
#2 Posted : 10 July 2014 23:45:24(UTC)
How about including unit-proof complex functions Re(), Im() and arg()? (SS-24)?
#3 Posted : 11 July 2014 01:22:05(UTC)
uploaded (big thanks to Andrey for the ultrafast bugfix Aggressive )
Be sure to have the "Exclude beta-versions" unchecked
Maybe in the Custom Functions as temporary patch (I prefer to have all the built-in functions unit-proofs, but I understand that this requires time)
Davide
Edited by user 11 July 2014 01:35:33(UTC)  | Reason: Not specified
on 11/07/2014(UTC),  on 11/07/2014(UTC)
Offline baijo
#4 Posted : 04 August 2014 23:37:49(UTC)
baijo
United Kingdom
Thank you very much.
Offline krissn
#5 Posted : 29 January 2018 20:29:06(UTC)
krissn
Rank: Member
United Kingdom
Can i suggest adding function to round calculated value to closest one of E-series (I'm talking about e.g. E96 series of resistors) ?
Kriss
Offline paltatech
#6 Posted : 11 June 2018 06:09:27(UTC)
paltatech
Argentina
It looks like the plugin isn't working
error
Or I am using it incorrectly?
#7 Posted : 11 June 2018 12:16:46(UTC)
Guess it is a bug. I'll check it ASAP.
#8 Posted : 12 June 2018 12:01:00(UTC)
Seems that something is changed in SMath Studio, now overloads with definite and undefinite number of arguments are in a conflict state.
As workaround in the dynamic assistant I've temporary removed the overloads with a single argument; you will still be able to use them and they will be the default when you insert one of the functions of the plugin (use tha argument separator key to add more arguments).
I'll address the issue SMath side later.
PLUGIN UPDATED
Edited by user 12 June 2018 12:03:40(UTC)  | Reason: Not specified
Offline paltatech
#9 Posted : 12 June 2018 18:48:43(UTC)
paltatech
Argentina
Um I'm a newbie but when I hit recalculate in that demo page the capacitance units get messed up.
By the way, how is the || operator typed in?
Thanks!
#10 Posted : 12 June 2018 19:45:36(UTC)
Confirmed, another thing to investigate. You can make it working removing the output unit customization on the rightmost placeholder.
Type EEL_CPar( or EEL_RPar( and add 1 or more arguments with your argument separator key.
Offline paltatech
#11 Posted : 12 June 2018 20:42:01(UTC)
paltatech
Argentina
The || tip worked right away, thanks!
#12 Posted : 14 June 2018 11:52:15(UTC)
Should be fixed now.
PLUGIN UPDATED
Offline paltatech
#13 Posted : 14 June 2018 16:44:20(UTC)
paltatech
Argentina
Thanks!
Offline marks2c
#14 Posted : 10 April 2022 02:28:12(UTC)
marks2c
New Zealand
Was thanked: 4 time(s) in 3 post(s)
Kriss
This could be very useful. There is an interesting solution for this here (used on my HP calculator): E24 Nearest Fraction Calculation. Thanks Takayuki HOSODA
Edited by user 10 April 2022 02:30:10(UTC)  | Reason: Attribution
Offline Razonar
#15 Posted : 10 April 2022 11:15:19(UTC)
Razonar
Uruguay
Was thanked: 826 time(s) in 523 post(s)
Hi. In the meantime, you can use this, but I didn't check it much so it may have some wrong values in the geometric series.
ESeries.sm (14kb) downloaded 34 time(s).
on 14/04/2022(UTC)
