27 Pages«<1112131415>»
Offline uni
#241 Posted : 26 June 2018 01:22:57(UTC)
uni
Updated. Small improvements.
XYPlot Examples.sm (25kb) downloaded 54 time(s).
XYPlot Examples.pdf (71kb) downloaded 64 time(s).
Russia ☭ forever
Viacheslav N. Mezentsev
on 26/06/2018(UTC),  on 26/06/2018(UTC)
#242 Posted : 26 June 2018 16:46:54(UTC)
Thanks Uni, interesting,
Contour X_Y plot [More Styles].sm (26kb) downloaded 40 time(s).
Offline uni
#243 Posted : 27 June 2018 00:28:00(UTC)
uni
Updated. Y2 axis now looks right. Small improvements.
Edited by user 27 June 2018 00:49:29(UTC)  | Reason: Not specified
Russia ☭ forever
on 27/06/2018(UTC),  on 27/06/2018(UTC),  on 27/06/2018(UTC)
Offline uni
#244 Posted : 05 July 2018 22:17:00(UTC)
uni
Updated. Fixed bug when zooming.
Russia ☭ forever
on 06/07/2018(UTC)
Offline uni
#245 Posted : 12 July 2018 15:23:44(UTC)
uni
Quote:
Pl see the attached. Can't enable outer border (using Tool Pallet).
I think it is after the latest update of XYPlot Region plugin.
Same with ZedGraph.
Yes you are right. I changed the look of the plugins: X-Y PLot, ZedGraph and NPlot. The border and area around the plot now hidden (transparent). This is a new design.
Do you really want to return the option of enabling the border?
Russia ☭ forever
Offline ndtma
#246 Posted : 12 July 2018 16:35:47(UTC)
ndtma
Sri Lanka
Thanks uni. Now I know it is by design.
IMHO it is alright without borders.
#247 Posted : 12 July 2018 19:13:45(UTC)
Good think is does affect 6179. Otherwise, it will make me pest off.
The borders allows clean/professional capture for publishing.
Offline uni
#248 Posted : 12 July 2018 19:30:52(UTC)
uni
It can't be done for this version, Jean. Life goes on, do not get off the train. There are still many stops ahead.
Russia ☭ forever
on 12/07/2018(UTC),  on 13/07/2018(UTC)
Offline uni
#249 Posted : 20 July 2018 12:18:10(UTC)
uni
Updated. Region evaluated with using the last store state when any properties changed.
EDIT: Don't use, some bugs present.
Edited by user 20 July 2018 13:36:00(UTC)  | Reason: Not specified
Russia ☭ forever
on 20/07/2018(UTC),  on 20/07/2018(UTC)
Offline uni
#250 Posted : 20 July 2018 16:59:40(UTC)
uni
Updated.
Changes:
- region evaluated with using the last store state when properties changed (removed, not stable);
- added ability to direct access to axis when double clicking on it;
- refactored.
Russia ☭ forever
thanks 4 users thanked uni for this useful post.
on 20/07/2018(UTC),  on 20/07/2018(UTC),  on 20/07/2018(UTC),  on 20/07/2018(UTC)
Online fedeghi
#251 Posted : 20 July 2018 19:54:21(UTC)
fedeghi
Was thanked: 24 time(s) in 16 post(s)
Looks like yesterday update has broken something when using Smath Viewer.
Works fine with .sm files, doesn't work with .exe
See error message here
Offline uni
#252 Posted : 20 July 2018 20:29:59(UTC)
uni
Maybe this is because LinqBridge dll now used (since June). I'm not sure, you need to ask Andrey about this problem. He is now busy with a new beta and you will have to wait a while.
Edited by user 20 July 2018 20:32:59(UTC)  | Reason: Not specified
Russia ☭ forever
Online fedeghi
#253 Posted : 20 July 2018 20:36:35(UTC)
fedeghi
Ok, understood.
Is there a way to rollback to yesterdays version?
I'm asking this because this morning I have been working on a file and saving the .exe and running it was working smoothly.
This evening I updated the plugin and now it doesn't.
So I would be happy to roll back to yesterday, at the moment :P
Edited by user 20 July 2018 20:39:40(UTC)  | Reason: Not specified
Offline uni
#254 Posted : 20 July 2018 20:45:32(UTC)
uni
Yes, it is possible. You just need to remove the last copy of plugin from the plugin folder:
C:\Users\User\Application Data\SMath\extensions\plugins\c12231ec-4873-43c1-a7d0-a167ebd17066
You need to remove downloaded folder (0.1.67xx.xxxx) and change the record in .ini file.
Russia ☭ forever
Online fedeghi
#255 Posted : 20 July 2018 22:06:18(UTC)
fedeghi
Houston we have a problem.
I messed around, don't know exactly how and have corrupted something.
I need to reinstall everything from scratch, but when I try to, SMath finds the previously installed plugin again.
Any clue on how to remove EVERYTHING and start from scratch?
Sorry to bother, so angry with myself.
Here below some infos
Can't disable version 36185
Error message when attempting to create a new XYPLOT
Configuration modifications...
Most critical, today work will not open...
Edited by user 20 July 2018 22:14:54(UTC)  | Reason: Not specified
Offline uni
#256 Posted : 20 July 2018 22:19:48(UTC)
uni
Try this.
1. Close SMath Studio
2. Remove folder 0.1.6775.30553.
Edit ini file:
Code:
0.1.6732.38438
0
XYPlotRegion.dll
3. Run SMath Studio.
Russia ☭ forever
Online fedeghi
#257 Posted : 20 July 2018 22:28:30(UTC)
fedeghi
Try this.
Edit ini file:
Code:
0.1.6732.38438
0
XYPlotRegion.dll
Done, same error messages. Cant' understand why 36185 is still listed in the plugin manager... Where the hell is that version coming from, since we removed its folder?
Offline uni
#258 Posted : 20 July 2018 22:33:34(UTC)
uni
Try to save entire c12231ec-4873-43c1-a7d0-a167ebd17066 folder in another place and remove it from \extensions\plugins at all. Restart SMath Studio. Plugin still exists?
Russia ☭ forever
Online fedeghi
#259 Posted : 20 July 2018 22:40:31(UTC)
fedeghi
I solved differently, just rolling back something very stupid (an overwrite) I did in C:\Program Files (x86)\SMath Studio\plugins.
1) I un-installed again smath.
2) I noticed that everything was gone except for a XYPlotRegion.dll file which was left there... So I understood how stupidly I moved it when trying to roll back to a previous version "on my own" (so stupid).
3) Deleted that .dll in the wrong folder, installed Smath back again, and I assume that while installing smath loaded back all the plugins as per D:\Users\FGhioni\AppData\Roaming\SMath\extensions\plugins dataset, including the beloved old version of XYPlot
Uni I really need to THANK YOU for the support!
Awesome software, awesome user community
Edited by user 20 July 2018 22:42:25(UTC)  | Reason: Not specified
Offline uni
#260 Posted : 02 August 2018 05:32:10(UTC)
uni
Updated. Axis general format changed.
Edited by user 02 August 2018 05:33:51(UTC)  | Reason: Not specified
Russia ☭ forever
on 02/08/2018(UTC),  on 02/08/2018(UTC)
Guest (2)
Similar Topics
X-Y Plot Region Plugin (Extensions)
by ndtma 24/06/2018 06:00:49(UTC)
X-Y Plot Region Plugin Problem (Questions)
by ndtma 20/06/2018 19:38:44(UTC)
