27 Pages«<1213141516>»
Offline fedeghi
#261 Posted : 02 August 2018 09:47:52(UTC)
fedeghi
Was thanked: 24 time(s) in 16 post(s)
Originally Posted by: uni Go to Quoted Post
Updated. Axis general format changed.
Hi uni, did you have the chance to test the new update also on Smath Viewer?
In case yes, if you could let us know so that users that are currently interested in Viewer compatibility (like me) can update safely.
Thanks Clap
Offline omorr
#262 Posted : 02 August 2018 10:52:52(UTC)
omorr
Rank: Administration
Serbia
This is happening for me when I just increase the power of x in X-Y plot (Win7 64bit).
At some higher power, say after 10,11 (it depends on the plot size - larger the plot smaller the power) it just become white and the regions disappear when you click on them. It seems it got stuck. But you can click on the power and reduce it. When you reduce it, regions got back and everything seems to be Ok.
thanks 2 users thanked omorr for this useful post.
on 02/08/2018(UTC),  on 04/08/2018(UTC)
#263 Posted : 02 August 2018 12:42:11(UTC)
Thanks Clap
Nope, the issue is still here and it is related to Xml serialization used in the plugin. I'm looking for possible fixes.
on 02/08/2018(UTC)
Online uni
#264 Posted : 02 August 2018 16:55:24(UTC)
uni
Radovan, this is normal. This is due to errors in drawing. Similar behavior is found in another plugin, but there is a workaround.
Quote:
This method just handles the case where one or more of the coordinates are outrageous,
or GDI+ threw an exception. This method attempts to correct the outrageous coordinates by
interpolating them to a point (along the original line) that lies at the edge of the ChartRect
so that GDI+ will handle it properly. GDI+ will throw an exception, or just plot the data
incorrectly if the coordinates are too large (empirically, this appears to be when the
coordinate value is greater than 5,000,000 or less than -5,000,000). Although you typically
would not see coordinates like this, if you repeatedly zoom in on a ZedGraphControl, eventually
all your points will be way outside the bounds of the plot.
I'll try to workaround the problem in the same way.
Russia ☭ forever
Viacheslav N. Mezentsev
#265 Posted : 02 August 2018 17:58:46(UTC)
This is a known problem: X_Y fails to accept too large/too small coordinates ranges.
And the trick is to set the X, Y ranges before putting the plot argument(s).
Too large/too small numbers aren't visible anyway, better manage otherwise.
Online uni
#266 Posted : 02 August 2018 20:32:29(UTC)
uni
Updated. Try now.
Russia ☭ forever
Offline omorr
#267 Posted : 02 August 2018 20:47:27(UTC)
omorr
Serbia
Updated. Try now.
Thank you uni. It does not stuck anymore. I just thought it might be inconvenient the way it worked before. White area instead of the plot and disappearing regions is not pleasant to see.
#268 Posted : 02 August 2018 21:13:27(UTC)
Fix committed to the SVN server. Error messages about missing LINQ and XmlSerializer assemblies shouldn't be a problem anymore.
P.S. Before changes applies plugin must be recompiled and published again by uni Online
Edited by user 04 August 2018 10:34:27(UTC)  | Reason: Not specified
on 02/08/2018(UTC)
Online uni
#269 Posted : 02 August 2018 21:36:02(UTC)
uni
Updated again. Smath Viewer supported.
Russia ☭ forever
on 03/08/2018(UTC),  on 04/08/2018(UTC),  on 04/08/2018(UTC)
Online uni
#270 Posted : 03 August 2018 06:27:05(UTC)
uni
Originally Posted by: ndtma Go to Quoted Post
Is it possible to plot text at a specified coordinate in X-Y Plot Region or ZedGraph Plot?
Updated. Text labels added.
Edited by user 03 August 2018 06:35:35(UTC)  | Reason: Not specified
Russia ☭ forever
thanks 5 users thanked uni for this useful post.
on 03/08/2018(UTC),  on 03/08/2018(UTC),  on 03/08/2018(UTC),  on 04/08/2018(UTC),  on 04/08/2018(UTC)
Offline ndtma
#271 Posted : 03 August 2018 09:00:06(UTC)
ndtma
Sri Lanka
Thank you uni. Its amazing and very useful.
Offline ndtma
#272 Posted : 03 August 2018 10:53:57(UTC)
ndtma
Sri Lanka
Following 2 issues noted with new update today.
1. Only integer values for x & y coordinates effective. Text Lables disappear when decimal values are used.
2. Changes in formatting of lines to spline not saved when worksheet is re-loaded.
Online uni
#273 Posted : 03 August 2018 17:11:16(UTC)
uni
Updated. Try now.
Trace settings can also be used with text labels (in mixed mode). The text label settings are used if specified, otherwise the trace settings are used.
Edited by user 03 August 2018 17:17:29(UTC)  | Reason: Not specified
Russia ☭ forever
#274 Posted : 03 August 2018 17:43:05(UTC)
Updated. Try now.
While you are in the plot design, is there any chance to improve Quick plot ?
Damned hard to leave with so many useless decimals.
Obviously, it concerns x_axis as well
Online uni
#275 Posted : 03 August 2018 17:49:46(UTC)
uni
This request is not for me. I'm not a SMath Studio developer. Additional features to the program should be specified in Feature Requests Forum.
Russia ☭ forever
Offline ndtma
#276 Posted : 03 August 2018 19:10:59(UTC)
ndtma
Sri Lanka
Updated. Try now.
Thanks. It works fine now.
Online uni
#277 Posted : 04 August 2018 04:42:56(UTC)
uni
Updated. Shapes added.
X-Y Plot. Draw shapes.sm (23kb) downloaded 41 time(s).
Russia ☭ forever
thanks 4 users thanked uni for this useful post.
on 04/08/2018(UTC),  on 04/08/2018(UTC),  on 04/08/2018(UTC),  on 04/08/2018(UTC)
Offline ndtma
#278 Posted : 04 August 2018 05:27:32(UTC)
ndtma
Sri Lanka
Thanks uni for adding shapes also. It is useful.
Online uni
#279 Posted : 04 August 2018 05:30:42(UTC)
uni
This is experimental. Maybe I'll add a line type, arc shape and something else.
Russia ☭ forever
Offline ndtma
#280 Posted : 04 August 2018 06:07:41(UTC)
ndtma
Sri Lanka
Yes please. Thank you.
Guest (2)
Similar Topics
X-Y Plot Region Plugin (Extensions)
by ndtma 24/06/2018 06:00:49(UTC)
X-Y Plot Region Plugin Problem (Questions)
by ndtma 20/06/2018 19:38:44(UTC)
