2 Pages<12
Offline uni
#21 Posted : 01 August 2018 18:54:24(UTC)
uni
Simple test 2.
DotNumerics.ode.test2.sm (22kb) downloaded 37 time(s).
DotNumerics.ode.test2.pdf (80kb) downloaded 37 time(s).
Russia ☭ forever
Viacheslav N. Mezentsev
on 02/08/2018(UTC),  on 02/08/2018(UTC)
#22 Posted : 02 August 2018 03:57:14(UTC)
Originally Posted by: uni Go to Quoted Post
Simple test 2.
Works nice conventional/visual [6179].
That document, if it would come from other designer
would pass my QA [Quality Assurance].
DotNumerics.ode.test2.sm (25kb) downloaded 36 time(s).
#23 Posted : 09 September 2018 20:23:36(UTC)
It seems that all the dotnumeric ode solver functions fail to add the last step to the solution. In the given example, the exact solution is (approximately) met if the end value of x is increased by one step (x_end/steps).
The sheet is easily extended to whatever ode solvers by adding their name to the search list. The actually available solvers depend on what plugins are installed.
Section Math ODE precision.sm (24kb) downloaded 56 time(s).
on 09/09/2018(UTC),  on 10/09/2018(UTC)
Offline uni
#24 Posted : 10 September 2018 12:48:25(UTC)
uni
Updated for SS 0.99.6824. Intervals issue fixed.
Russia ☭ forever
on 10/09/2018(UTC),  on 10/09/2018(UTC),  on 10/09/2018(UTC)
Offline uni
#25 Posted : 06 December 2018 20:42:53(UTC)
uni
Updated.
Changes:
- zero point issue fixed;
- added support for the simple D(t,x) definition.
Russia ☭ forever
Offline uni
#26 Posted : 24 December 2018 15:13:53(UTC)
uni
Updated.
dn.ode.kinetic1.sm (9kb) downloaded 84 time(s).
dn.ode.kinetic2.sm (13kb) downloaded 63 time(s).
dn.ode.kinetic3.sm (13kb) downloaded 61 time(s).
dn.ode.test1.sm (20kb) downloaded 68 time(s).
dn.ode.test2.sm (19kb) downloaded 67 time(s).
dn.ode.Amplitude detector.sm (21kb) downloaded 71 time(s).
dn.ode.kinetic1.pdf (78kb) downloaded 69 time(s).
dn.ode.kinetic2.pdf (94kb) downloaded 49 time(s).
dn.ode.kinetic3.pdf (92kb) downloaded 46 time(s).
dn.ode.test1.pdf (116kb) downloaded 46 time(s).
dn.ode.test2.pdf (121kb) downloaded 47 time(s).
dn.ode.Amplitude detector.pdf (149kb) downloaded 48 time(s).
Edited by user 25 December 2018 02:59:43(UTC)  | Reason: Not specified
Russia ☭ forever
thanks 4 users thanked uni for this useful post.
on 24/12/2018(UTC),  on 24/12/2018(UTC),  on 24/12/2018(UTC),  on 24/12/2018(UTC)
#27 Posted : 25 December 2018 20:49:08(UTC)
Native works as well.
You can try rkfixedSteven.
#28 Posted : 25 December 2018 22:25:11(UTC)
Read + interesting stuff.
Chemical Kinetics: Introduction with Mathcad/Maple/MCS. Chapter 3
Edited by moderator 26 December 2018 01:00:17(UTC)  | Reason: Not specified
on 26/12/2018(UTC)
Offline uni
#29 Posted : 09 December 2021 15:10:25(UTC)
uni
SMath Studio compatibility
Plugin updated.
Changes:
- added support the mathematical form of the problem for ODE solvers;
- refactored.
Russia ☭ forever
on 09/12/2021(UTC)
Offline uni
#30 Posted : 20 December 2021 22:18:13(UTC)
uni
Plugin updated.
Changes:
- solution restructured;
- converting the task for the ODE solver to the numerical form is now performed through the Mathcad Toolbox plugin (to avoid code duplication), so it must be installed;
- refactored.
Solvers that support mathematical notation now reuse code from the Mathcad Toolbox plugin. Now there is no need to recompile every such plugin.
Russia ☭ forever
Offline Razonar
#31 Posted : 21 August 2022 08:43:28(UTC)
Razonar
Uruguay
Was thanked: 817 time(s) in 517 post(s)
Hi Viacheslav. There are an issue with Implicit and dn_ExplicitRK45, just in the first element. Please see the attached.
dn_ExplicitRK45 issue.sm (9kb) downloaded 10 time(s).
on 22/08/2022(UTC)
Offline uni
#32 Posted : 22 August 2022 09:12:45(UTC)
uni
Plugin updated.
Changes:
- fixed values of initial conditions in the output array for dn_ImplicitRK5() and dn_ExplicitRK45().
Russia ☭ forever
on 22/08/2022(UTC),  on 24/08/2022(UTC)
2 Pages<12
