3 Pages<123
Offline uni
#41 Posted : 24 December 2018 13:47:08(UTC)
uni
Updated.
alglib.ode.kinetic1.sm (8kb) downloaded 76 time(s).
alglib.ode.kinetic2.sm (11kb) downloaded 58 time(s).
alglib.ode.kinetic3.sm (11kb) downloaded 65 time(s).
alglib.ode.test1.sm (11kb) downloaded 66 time(s).
alglib.ode.test2.sm (11kb) downloaded 58 time(s).
alglib.ode.Amplitude detector.sm (20kb) downloaded 68 time(s).
alglib.ode.kinetic1.pdf (76kb) downloaded 64 time(s).
alglib.ode.kinetic2.pdf (90kb) downloaded 46 time(s).
alglib.ode.kinetic3.pdf (84kb) downloaded 54 time(s).
alglib.ode.test1.pdf (86kb) downloaded 49 time(s).
alglib.ode.test2.pdf (90kb) downloaded 42 time(s).
alglib.ode.Amplitude detector.pdf (148kb) downloaded 53 time(s).
Edited by user 25 December 2018 20:24:43(UTC)  | Reason: Not specified
Russia ☭ forever
Viacheslav N. Mezentsev
thanks 5 users thanked uni for this useful post.
on 24/12/2018(UTC),  on 24/12/2018(UTC),  on 24/12/2018(UTC),  on 24/12/2018(UTC),  on 24/12/2018(UTC)
Offline uni
#42 Posted : 28 December 2018 20:02:54(UTC)
uni
Updated. Refactored.
Russia ☭ forever
on 28/12/2018(UTC),  on 29/12/2018(UTC),  on 29/12/2018(UTC)
Offline uni
#43 Posted : 19 January 2019 22:31:14(UTC)
uni
Updated. al_nleqsolve(2), al_nleqsolve(3), al_nleqsolve(4) added.
Edited by user 20 January 2019 01:54:35(UTC)  | Reason: Not specified
Russia ☭ forever
on 19/01/2019(UTC),  on 20/01/2019(UTC),  on 20/01/2019(UTC)
Offline uni
#44 Posted : 27 January 2019 11:23:49(UTC)
uni
With numeric optimization (for all functions) it works much faster.
Fourier series coefficients.sm (18kb) downloaded 53 time(s).
Fourier series coefficients.pdf (139kb) downloaded 46 time(s).
Edited by user 27 January 2019 16:42:03(UTC)  | Reason: Not specified
Russia ☭ forever
thanks 4 users thanked uni for this useful post.
on 27/01/2019(UTC),  on 27/01/2019(UTC),  on 27/01/2019(UTC),  on 27/01/2019(UTC)
Offline uni
#45 Posted : 27 January 2019 16:59:21(UTC)
uni
Example 2.
Fourier series coefficients.sm (29kb) downloaded 104 time(s).
Fourier series coefficients.pdf (171kb) downloaded 77 time(s).
Russia ☭ forever
on 27/01/2019(UTC)
#46 Posted : 27 January 2019 18:48:06(UTC)
Otherwise w/o Algib and more Engineering applications
Fourier Budapest39 Smoothing.sm (48kb) downloaded 49 time(s).
#47 Posted : 27 January 2019 19:06:32(UTC)
Fourier-Fejer-Lanczos interesting too.
IrfanView "ResizeResample" zoom up/down in two options
Fourier or Lanczos the best.
Fourier Fejer Lanczos.sm (10kb) downloaded 49 time(s).
Offline Ber7
#48 Posted : 18 February 2019 11:42:17(UTC)
Ber7
Israel
Was thanked: 520 time(s) in 288 post(s)
Parameterization of implicit functions with al_nleqsolve
Parametrisation.sm (30kb) downloaded 53 time(s).
thanks 4 users thanked Ber7 for this useful post.
on 18/02/2019(UTC),  on 18/02/2019(UTC),  on 18/02/2019(UTC),  on 18/02/2019(UTC)
Offline Razonar
#49 Posted : 18 February 2019 19:59:33(UTC)
Razonar
Uruguay
Was thanked: 826 time(s) in 523 post(s)
Hi Ber. Nice technique, easy to implement. You can also make that as a function, and monocolor too.
Parametrisation.sm (26kb) downloaded 54 time(s).
Another option could be use y0 as vector, and solve for each element in y0, obtaining res, res1, ..., resn
on 18/02/2019(UTC)
#50 Posted : 19 February 2019 05:53:03(UTC)
1. SS 6179 does not complain
2. Takes ~ 1 hr to terminate the first function
3. NO plot result [NO complain but NO plot ?]
4. Would be interesting checking if the attached SS 6179
runs in your actual AlgLib 3.1x. If NOT => would be a dramatic bug.
It would indicate that all maths based al_nleqsolve would be scrap.
Contour SOLVE [Electron Solve algo Express].sm (21kb) downloaded 55 time(s).
Offline uni
#51 Posted : 22 November 2020 10:47:54(UTC)
uni
Updated.
Changes:
- source code updated to ALGLIB 3.16.0;
- refactored.
Edited by user 22 November 2020 11:21:45(UTC)  | Reason: Not specified
Russia ☭ forever
Offline uni
#52 Posted : 22 February 2021 22:06:56(UTC)
uni
Updated.
Changes:
- source code updated to ALGLIB 3.17.0;
Russia ☭ forever
on 17/11/2021(UTC)
Offline uni
#53 Posted : 17 November 2021 17:42:24(UTC)
uni
SMath Studio compatibility
Plugin updated.
Changes:
- source code updated to ALGLIB 3.18.0;
- al_polyroots() function added.
Russia ☭ forever
on 17/11/2021(UTC),  on 17/11/2021(UTC),  on 17/11/2021(UTC),  on 17/11/2021(UTC)
Offline uni
#54 Posted : 08 December 2021 08:43:14(UTC)
uni
Plugin updated.
Changes:
- al_lspline(), al_pspline() fucntions added;
- some functions now have a reduced number of parameters (input vector lengths are no longer required);
- refactored.
Russia ☭ forever
Offline uni
#55 Posted : 10 December 2021 07:36:46(UTC)
uni
Plugin updated.
Changes:
- added support for ODE systems in mathematical form;
- refactored.
Russia ☭ forever
on 10/12/2021(UTC)
Offline uni
#56 Posted : 20 December 2021 22:18:35(UTC)
uni
Plugin updated.
Changes:
- solution restructured;
- converting the task for the ODE solver to the numerical form is now performed through the Mathcad Toolbox plugin (to avoid code duplication), so it must be installed;
- refactored.
Solvers that support mathematical notation now reuse code from the Mathcad Toolbox plugin. Now there is no need to recompile every such plugin.
Russia ☭ forever
3 Pages<123
