14 Pages«<11121314>
Offline Razonar
#241 Posted : 12 February 2019 05:43:29(UTC)
Razonar
Uruguay
Was thanked: 820 time(s) in 519 post(s)
Originally Posted by: omorr Go to Quoted Post
Thank you Alvaro for your interest in these problems. Here is the file once more.
Hi Radovan. Thanks you for answer. I'm not clear, I refer to the initials conditions in the mathcad worksheet, phi, x and y. And k too. Are the same than in the smath file?
Offline Razonar
#242 Posted : 12 February 2019 07:57:54(UTC)
Razonar
Uruguay
Hi. Don't worry for the mathcad values, SMath is powerful. Here a way to solve Radovan's flash problem.
Primer38-doomed 2.sm (72kb) downloaded 58 time(s).
thanks 2 users thanked Razonar for this useful post.
on 12/02/2019(UTC),  on 12/02/2019(UTC)
Offline omorr
#243 Posted : 12 February 2019 10:56:01(UTC)
omorr
Rank: Administration
Serbia
Thank you Alvaro very much Good . That's exactly I was talking about Good
It could be solved by using your great function SNRxy() function. I did it long time ago by some similar home made functions as well. The main point is that we should also could have solve the same problem with some of the functions from, say, this NonlinearSolves plugin. You might use, say Broyden() or some other function but it seems it does not work anymore, or at least I forgot or do not know how to use it. As I mentioned before, NonlinearSolvers plugin (IMHO) is the only one adressing these problems but it was not updated for a long time.
Offline omorr
#244 Posted : 12 February 2019 14:21:45(UTC)
omorr
Serbia
Just for the record. Slightly changed, maybe less correct posed, but solved correctly Good
To excuse myself and thank Alvaro and Jean once more. I unintentionally deleted some regions regarding initial conditions and introduced a confusion a bit, and figured out by rechecking the things.
Primer38-undoomed.sm (72kb) downloaded 39 time(s).
Edited by user 12 February 2019 18:31:41(UTC)  | Reason: Not specified
#245 Posted : 12 February 2019 22:52:51(UTC)
... a bit more Pro.
#246 Posted : 13 February 2019 18:37:26(UTC)
Interesting to know SNRxy(a,N,εx,εy) works fine in your latest SS version.
Two pieces of code SS 6179 does not digest [@ big arrow].
FindRoot works fine manual patience, but could not make work in forloop.
As done, it saturates @ 12 decimals with the two degree of freedom.
I have done my best for myself if any useful for more visitors.
I could see some Matlab code wrt matrices A,B but does explain where
they come from. Still missing some abstract for readers.
Thanks Radovan, Alvaro ... most appreciated.
In short => SS 6179 does not cut the mustard ! a British expression.
Project Solve Flashing Copy.sm (205kb) downloaded 32 time(s).
Offline omorr
#247 Posted : 13 February 2019 19:53:18(UTC)
omorr
Serbia
Than you Jean for being supportive,
It crossed my mind that my first post here was almost 10 years ago. It seems that I am repeating myself periodically.
Best Regards,
Edited by user 13 February 2019 19:56:45(UTC)  | Reason: Not specified
on 13/02/2019(UTC)
Offline Razonar
#248 Posted : 14 February 2019 00:48:44(UTC)
Razonar
Uruguay
Hi. The troubles that I find solving this is that can't use the normal call for functions, as it is showed at the end, where fails to call the same Newton-Raphson code, but with F(1) and C(1).
This must to be some kind of bug calling functions when the definition of the functions it's complicate or implies the vectorization for the args.
Primer38-undoomed - redoomed.sm (76kb) downloaded 35 time(s).
on 14/02/2019(UTC)
#249 Posted : 14 February 2019 01:25:01(UTC)
The "redooomed" downloaded but can't open yet. It might suffer same
auto-consumption than FindRoot, i.e: it does not clear itself within a for loop.
It must be called from an external forloop. Will post soon a semi-elegant way
of descending the FindRoot that needs several iterations as it is ± 3 decimals
from the Smath native module. I get 0.0000000000001 as final sanity solutions.
Takes ~ 5 minutes of manual iterations ... Jean is happy !
Cheers Alvaro.
#250 Posted : 14 February 2019 06:44:31(UTC)
Like when you start speaking to yourself, indicates the Man is in good growing conditions.
That version is refreshed in 8 manual iterations, easy to use.
Start by the very initials [xo, yo]
Project Solve Flashing Copy.sm (210kb) downloaded 23 time(s).
on 14/02/2019(UTC)
Offline omorr
#251 Posted : 14 February 2019 10:49:46(UTC)
omorr
Serbia
Thank you Alvaro for this. This was a logical thing to do in order to improve your function. Moreover, the "spooky" thing "xx-not defined" appears here and there and I often do not have a clue why. It often appears when you want to use eval(). Someone might have an explanation for this effect you represented in this example, but it still makes me confused and it seems it will remain that way. I suppose you understand now why I called this one as "doomed".
#252 Posted : 14 February 2019 16:35:36(UTC)
"can't calculate spooky" because like Mathcad, can't trace back
in the program [generally]. The other spooky about FindRoot
"can't find variables ... try a more specific algorithm "
Often, we get red spooky like you show but calculations are done.
Just adapt a bit of coding to calm down SS from complaining.
Simply spooky syntax as you show.
#253 Posted : 29 January 2020 17:59:54(UTC)
In build 7251, there is a problem with Taylor(), see screenshot. Bugreport filed as SS-4631
Taylor.sm (22kb) downloaded 30 time(s).
Offline GlennTg
#254 Posted : 20 September 2022 11:10:00(UTC)
GlennTg
Belgium
I encountered the bug as well in the latest version (build 8253) with plugin version 1.1.7097.23301, and as far as I can see, the latest update is from 2019: https://en.smath.com/vie...055-9e577672f0b8/summary
Is this plugin still being maintained, or should I look for another solution?
Thanks in advance!
#255 Posted : 20 September 2022 15:07:31(UTC)
you can circumvent the issue using a single-argument line()
I'll check if there is a solid way to fix it, preprocessing in symbolic functions sometimes is hard to handle in many ways....
Offline GlennTg
#256 Posted : 20 September 2022 15:56:29(UTC)
GlennTg
Belgium
Thanks for your reply!
However, I cannot reproduce the workaround.
I also thought the 2nd argument was supposed to be 'x', the variable of the function, but you use '2'? Do I have a wrong understanding?
Thanks again.
#257 Posted : 20 September 2022 16:05:29(UTC)
Try changing the optimization on the region that shows the error to "symbolic" or "none"
It can be either a number or a variable name (x, x0, z, ...).
#258 Posted : 20 September 2022 16:18:18(UTC)
As far as Taylor is concerned, there is no bug in Smath.
Taylor is not a function. Simply a Classroom quick plot demo.
What it plots is not otherwise possible to evaluate.
However, you can play/productive with the spooky Taylor.
Cheers ... Jean ... hope it clarifies.
Offline GlennTg
#259 Posted : 20 September 2022 17:00:16(UTC)
GlennTg
Belgium
Thank you all for the replies!
#260 Posted : 21 September 2022 17:58:53(UTC)
The missing document.
Maths Taylor Spooky.sm (21kb) downloaded 10 time(s).
14 Pages«<11121314>
