SMath Studio Forum
Download SMath Studio
Archive
Stable: SMath Studio 0.99.7005 (07 March 2019)
They talk about us
Smath is easy to use tool and its is freeware.I used for engineering calculations instead of easing excel. Its a time saver.
more...
by Naresh varikuntla
This program helped me in solving a lot of my mechanical problems related to gears, design standards & structural problems.
Now we can run it on our mobiles also. Thanks for this useful program.
more...
by Sudhir Gill
Great free software. I use it for calculations of civil structures. Thanks a lot.
more...
by Antonio Fazzutti
- Desktop (Linux):
- [BUL] Bulgarian / Български
- [CAT] Catalan / Català
- [CZE] Czech / Čeština
- [DAN] Danish / Dansk
- [DUT] Dutch / Nederlands
- [ENG] English / English
- [FAS] Persian / فارسی
- [FIN] Finnish / Suomi
- [FRE] French / Français
- [GER] German / Deutsch
- [GRE] Greek / Ελληνικά
- [HEB] Hebrew / עברית
- [HUN] Hungarian / Magyar
- [ITA] Italian / Italiano
- [JPN] Japanese / 日本語
- [KOR] Korean / 한국어
- [LAV] Latvian / Latviešu
- [LTH] Lithuanian / Lietuvių
- [NOR] Norwegian / Norsk
- [POL] Polish / Polski
- [RON] Romanian / Română
- [RUS] Russian / Русский
- [SCR] Croatian / Hrvatski
- [SLK] Slovak / Slovenčina
- [SPA] Spanish / Español
- [SWE] Swedish / Svenska
- [TUR] Turkish / Türkçe
Introduction of the use of SMath Studio by Gilberto E. Urroz, Ph.D., P.E. Other files SMath Studio icons ( ) of all available sizes (16x16, 24x24, 32x32, 48x48, 64x64, 96x96, 128x128, 256x256) in PNG format.
on 07/03/2019(UTC), on 07/03/2019(UTC), on 07/03/2019(UTC), on 08/03/2019(UTC), on 08/03/2019(UTC), on 08/03/2019(UTC), on 08/03/2019(UTC), on 08/03/2019(UTC), on 10/03/2019(UTC), on 30/03/2019(UTC)
I appreciate all your hard work on this software; however, please turn off the popup trying to install the 7005 version every time I open my 6884 version. There are too many plugins that I need that no longer work with the 7005 version. Thanks again for all your hard work. Reg curry
Originally Posted by: RegCurry please turn off the popup trying to install the 7005 version every time I open my 6884 version Go to: Tools > Plugins... > SMath Studio then enable the option "Don't check for updates" |
I did. However, now I cannot even use the older version with maple or XY plots. This has totally ruined my workflow. Let me know when this is fixed and I will return to Smath. :'(
Also, there is not Tools>Plugins>SMath Studio There is only Tools>Plugins>Online gallery
Thanks for adding in the maple and XY plot plugins.
Originally Posted by: RegCurry I did. However, now I cannot even use the older version with maple or XY plots. This has totally ruined my workflow. Let me know when this is fixed and I will return to Smath. :'( I generally recommend to not upgrade the installed version until you verified that new versions are functional to the level you need. To test new versions, use the linux version (yes, it runs under Windows and yes it is significantly smaller), unpack it to some directory and add a file named portable.version to that directory. Then you have a sandbox which is totally independent of the "installed" SMath version. |
Originally Posted by: RegCurry Also, there is not Tools>Plugins>SMath Studio There is only Tools>Plugins>Online gallery Is the first item in the left panel Originally Posted by: RegCurry I did. However, now I cannot even use the older version with maple or XY plots. Once you reinstalled the old program version go in the Extensions Manager (Tools > Plugins) and remove the plugins you have previously updated in the newer version (select each plugin that has a red backkground or didn't work as expected, then click on the trash bin), finally switch the top right button from "Local Storage" to "Online Gallery" and reinstall the extensions you need. Edited by user 08 March 2019 11:45:19(UTC)
Joined: 07/12/2018(UTC) Posts: 44 Was thanked: 1 time(s) in 1 post(s)
Добрый день, уважаемые эксперты SMath.
Спасибо за вашу работу и за новое обновление SMath Studio. Я обратил внимание на следующую особенность в новоей стабильной версии Smath 0.9.0075.xxx, когда пользователь удаляет строки в документе с помощью клавиши 'Delete‘. Так не виден маркер удалемых строк и вообще строка статична. Она не двигается вверх, пока жмешь кнопку 'Delete‘. И только потом после операции удаления нескольких строк весь документ сдвигается вверх. А во сколько строк удаляется в процессе удержания кнопки 'Delete‘ - неизвестно . Если риск удалить и сам фрагмент текста или формулы, если маркер находится над ними и пользователь удерживает кнопку 'Delete‘.
С уважением Андрей
p.s. могу выложить видео, но не знаю как на форуме это видео выложить
Was thanked: 16 time(s) in 7 post(s)
Originally Posted by: mkraska I generally recommend to not upgrade the installed version until you verified that new versions are functional to the level you need.
Martin- Thank you for this! How do you recommend to handle the different plugin versions? If there is a version update to the plugin, is it safe to assume that the updated plugins are 100% backward compatible? Thanks Dennis |
Originally Posted by: sinneD Originally Posted by: mkraska I generally recommend to not upgrade the installed version until you verified that new versions are functional to the level you need.
Martin- Thank you for this! How do you recommend to handle the different plugin versions? If there is a version update to the plugin, is it safe to assume that the updated plugins are 100% backward compatible? Thanks Dennis If you are working with different portable versions, then you have separate directories for each of them. Each version has it's own extensions subdirectory, which you need to fill using the extension manager. Then the extension manager should offer you the plugin versions appropriate for the particular SMath version. Usually this works reliably. Never just copy the extension subdir from some other portable version. |
German handbook updated. Available via Extension manager or website. |
on 17/03/2019(UTC), on 17/03/2019(UTC)
Andrey, did you deliberately change shortcuts for greek letters?
f Ctrl-G now produces the closed phi sign (\phi in LateX). In previous versions it used to produce the open version of the sign (\varphi)
I'd vote for the old version.
on 20/03/2019(UTC), on 22/03/2019(UTC)
they got flipped-flopped- i did not notice until you pointed it out. i remembered the mention that it was added the 2 'special' greek chars, but I could not figure what it meant until i looked at the symbols panel. if you hover over the symbol, it gives you the shortcut in the new version. curiously, in 6839, the hotkey work, i do not remember when they got added. |
2 users thanked sinneD for this useful post.
on 21/03/2019(UTC), on 22/03/2019(UTC)
Originally Posted by: mkraska Andrey, did you deliberately change shortcuts for greek letters?
Looks like a bug. Will fix it. Thank you!
SMath Studio Forum
Archive
