Offline Andrey Ivashov
#1 Posted : 01 April 2019 01:28:17(UTC)
Rank: Administration
Created by SMath LLC in the scope of SMath project. Published by smath.
SMath Studio box
They talk about us
This is a must have software for engineering student. more...
by Rabbi
Thank you for SMath. It's been a life saver. more...
by Bob Johansson P.Eng.
Smath is easy to use tool and its is freeware.I used for engineering calculations instead of easing excel. Its a time saver. more...
by Naresh varikuntla
System requirements
  • Desktop (Windows):
  • Desktop (Linux):
Interface languages (37 languages)
  • [ARA] Arabic / العربي
  • [BUL] Bulgarian / Български
  • [CAT] Catalan / Català
  • [CZE] Czech / Čeština
  • [DAN] Danish / Dansk
  • [DUT] Dutch / Nederlands
  • [ENG] English / English
  • [FAS] Persian / فارسی
  • [FIN] Finnish / Suomi
  • [FRE] French / Français
  • [GER] German / Deutsch
  • [GRE] Greek / Ελληνικά
  • [HEB] Hebrew / עברית
  • [HUN] Hungarian / Magyar
  • [ITA] Italian / Italiano
  • [JPN] Japanese / 日本語
  • [KOR] Korean / 한국어
  • [LAV] Latvian / Latviešu
  • [LTH] Lithuanian / Lietuvių
  • [NOR] Norwegian / Norsk
  • [POL] Polish / Polski
  • [RON] Romanian / Română
  • [RUS] Russian / Русский
  • [SCR] Croatian / Hrvatski
  • [SLK] Slovak / Slovenčina
  • [SPA] Spanish / Español
  • [SWE] Swedish / Svenska
  • [TUR] Turkish / Türkçe
  • [UKR] Ukrainian / Українська
Tutorial
Other files
thanks 8 users thanked Andrey Ivashov for this useful post.
on 01/04/2019(UTC),  on 01/04/2019(UTC),  on 01/04/2019(UTC),  on 01/04/2019(UTC),  on 01/04/2019(UTC),  on 02/04/2019(UTC),  on 05/04/2019(UTC),  on 30/04/2019(UTC)
Offline Artyom
#2 Posted : 26 November 2019 19:34:41(UTC)
Artyom
Poland
Is there a way to open several instances of the app in that version? Not like a few windows with different documents, but few system windows with different documents. Looks like it doesn't work now, but worked in previous version. Now it's super inconvenient because it's impossible to work on few monitors in different files at the same time.
#3 Posted : 27 November 2019 02:20:36(UTC)
Not clear what you could do before and not anymore.
When you open a PC session, you have nothing yet
At this point: click on the Smath icon TaskBar ... bingo Smath.
From there, you can open any Smath work sheet from wherever
in the PC box as you have a single Smath session.
Now, if you want another Smath session, double click on the
Smath icon in the DeskTop ... not TaskBar.
You then have a 2nd Smath session identified page 1.
Do that as many times as you want independent Smath sessions.
Now, to reach those Smath sessions, hover on the Smath icon
on the TaskBar ... click on the one you want identified page 1.
From the Smath menu "Open", browse for the document you want
from wherever in the PC box. Do same for the other not yet opened.
Now, you have as many Smath sessions as desired for each of
your active screen for multiple consultations.
But, all that is BS & BK [Bull Shit & Book Keeping].
Open documents from a single Smath sessions ... open any number,
I know no limit. From your individual screen just consult the
one in cause. Just works great Win 7, SS 6179.
It can be done other wise.
Offline Razonar
#4 Posted : 27 November 2019 13:41:54(UTC)
Razonar
Uruguay
Was thanked: 830 time(s) in 526 post(s)
Hi. I ask for this feature, which is good for low resources systems, because SMath is some slow starting. I guess that it's in the c:\Users\##USER##\AppData\Roaming\SMath\settings.inf the option, but can't find where.
Check this: https://en.smath.com/forum/yaf_postst17103_About-messages-and-smath-instances.aspx
Hope this helps.
ALvaro.
#5 Posted : 27 November 2019 16:32:09(UTC)
Does it work this way for you ?
3 double click on the Smath icon Desktop.
The first Smath instance takes > 1 min
2nd & 3rd instance 45 sec.
Now, you have 3 Smath sessions, each one to be filled
from your main Smath documents directory
SS 6179 Win 7
Offline fedeghi
#6 Posted : 09 June 2020 10:37:52(UTC)
fedeghi
Was thanked: 24 time(s) in 16 post(s)
Hello, new stable builds have not been release for a while now (more than one year).
I would like to know if future plans for development on smath are still ongoing and, in case, if a new stable build is going to be released?
Thanks
Bye!
#7 Posted : 16 July 2020 10:58:00(UTC)
Everything is OK. It is not a first time in a project's lifetime when development was paused.
Currently I've almost finished work on my other projects so plan to return to SMath very soon.
on 16/07/2020(UTC),  on 16/07/2020(UTC),  on 16/07/2020(UTC),  on 17/07/2020(UTC)
Offline overlord
#8 Posted : 16 July 2020 14:51:49(UTC)
Turkey
I had begun to worry about you dear Andrey.
Since so much bad news is happening in 2020...
It is good to hear you are doing well.
Offline odusbav
#9 Posted : 16 July 2020 18:00:08(UTC)
odusbav
Venezuela
Thats great andrey, I honestly was fearing the worst had happened.
btw could you look into the no symbols shown in toolbox bug we linux users are facing?
