Offline Andrey Ivashov
#1 Posted : 09 January 2012 06:37:10(UTC)
Rank: Administration
New SMath Studio 0.90 Stable available
SMath Studio Handheld on the Smartphone
Quote:
Controls:
With consecutive pushing of this button you can choose: "1", delimiter of the number ",", "square root - sqrt", "n-th root - nthroot", "integral - int", "function to find roots of equations - solve". To lock any variant just stop pushing this button 1 second.
With consecutive pushing of this button you can choose: "number related to the button", "symbols related to this button". To lock any variant just stop pushing this button 1 second.
With consecutive pushing of this button you can choose: "plus operator", "minus operator", "multiplication operator", "division operator", "exponentiation operator", "plus/minus operator", "factorial", "vector multiplication operator". Also with this pushed button you can highlight the part of equation by using Left/Right buttons.
By "clicking" on this button program will numerically calculate equation (this means "="); by pushing button more than 0,4 sec. program will symbolically calculate equation (this means "->"). Also, if the cursor located on the right of the not defined variable or not defined function this button will create a definition operator (this means ":=" ).
Removing last character (Backspace). In the mathematical reference book this button means "Back".
SMath Studio Handheld on the Communicator (PPC)
Last changes
  • Added ability to zoom the worksheet using Ctrl+Mouse Wheel or via GUI (Menu on the Status Bar);
  • Added ability to create plugins to extend SMath Studio worksheet with new types of Regions (Custom Regions);
  • Translatable Units implemented;
  • Graph animation implemented;
  • Exponential threshold setting added;
  • Performance of the el(..), rows(..), cols(..) and length(..) functions improved;
  • Added ability to show/hide grid on the Plot Control;
  • Added ability to show/hide axes on the Plot Control;
  • Symbolic library simplification engine improved;
  • Added support for *.txt files to drag'n'drop to the Worksheet;
  • Added ability to display text as a result for the Math Regions with manually specified Units;
  • Example of animation added: PlanetaryGear.sm;
  • Added ability to show current language for the Translatable Regions;
  • Worksheet's context menu improved to display languages supported for the Region;
  • Plot Region and Math Region components extended to support hidden input data mode;
  • Settings dialog reworked: some of the options require program restart now;
  • Context menu of Math Region extended with options: Decimal Places, Exponential Threshold and Fraction type;
  • Added ability to use value recommended by Dynamic Assistance by Enter pressing;
  • In the Dynamic Assistance hint "TAB+Shift" replaced with "Shift+TAB";
  • Pictures saves in XML using base64 format now instead of binhex (output files size decreased);
  • Backspace behavior improved for Math Region (f.e. in expression "1+2" it takes 3 backspace' uses to remove all);
  • Plot 2D and Plot 3D buttons removed from the math toolbar panel;
  • Math Region improved;
  • Worksheet's Context Menu improved;
  • Translatable Regions interfaces improved;
  • Units importing from XML file implemented;
  • Beam example corrected;
  • Home and Back buttons fixed for the Math Book;
  • Fixed changing of the border for multiple selected Regions when Regions has different border value;
  • Fixed error appears on moving Collapsed Area using Up/Down/Left/Right keyboard buttons;
  • Fixed issues appears after pasting Regions (lost metadata etc);
  • Fixed error of application opening on multi-monitor configuration (program will open on the connected display only);
  • Fixed errors with Units for zero;
  • Fixed error appears on file Save if only SMath Studio files plugin installed;
  • Save file dialog will not be shown if no file plugins installed;
  • Handling of the messages from plugins improved (fixed issue about invisible regions on Worksheet's load);
  • Solve function limits issue fixed;
  • Fixed issue appears when pasted image was shown outside of the visible Worksheet bounds;
  • Fixed issue with All Units item shown twice into the Insert Units Dialog;
  • New interface languages added: CAT, FAS, FIN, HEB, LAV, SLK, SWE;
  • Language files updated;
  • Refactoring.
Changes since last stable 0.89 (was introduced in beta 0.89.8 earlier)
  • Area Regions with protection ability implemented;
  • Snippets feature implemented;
  • ImageFileType plugin included (it adds an ability to save whole worksheet into *.png, *.gif, *.jpeg and *.bmp image formats);
  • Support for Compressed SMath File type (*.smz) added;
  • Added ability to use functions as programs (i.e. programming functions can be used into the right part of definition expression);
  • Added ability to move up all Regions of the Worksheet below the cursor using Delete keyboard button;
  • Added ability to exclude Area regions from print out;
  • Added ability to replace all definitions and equalities with a "=" sign on print out;
  • "Beam load calculation bearing with two supports" example included into the Examples Dialog of SMath Studio;
  • GravitationAcceleration.sm example file translated to IND;
  • Sorting improved in the Dynamic Assistance list when items with subscript in there names exists;
  • Angles global option removed from the Options Dialog;
  • Several physical constants added to the built-in list of Units: G.N, h, N.A, μ.0, e, m.e, m.p, m.n, m.u, R.gas, k;
  • Units "erg", "grad" and "gon" added to the built-in list of Units;
  • Dynamic Assistance hint tooltip implemented (it shows what keystrokes can be used to work with Dynamic Assistance);
  • Added ability to draw text on the 2D Plot Control canvas;
  • Added ability to draw special characters on the Plot Control canvas;
  • IsDefined(..), roots(..) and Jacob(..) functions added to SpecialFunctions plugin;
  • Ability to open/save *.sm file types are moved to plugin;
  • Line function alignment corrected to top;
  • Text and units inside math regions now keeps their colors even if the color of region's background is changed by user;
  • Desktop: Fixed Area/Separator print issue when its width was wrong on print out;
  • Dynamic Assistance now doesn't appear on Ctrl+G keystroke into the Text elements of the Math region;
  • Last digits of the built-in constants corrected into the Dynamic Assistance hints;
  • Fixed critical error appeared on Control Paint error ("Red Cross Death" exception);
  • Limitation of the summation function arguments removed, now it is possible to set top limit less then bottom limit;
  • Fixed Units power error when "Real" or "Imaginary" item chosen of the "Answer (set)" option in Options Dialog;
  • HTMLFileType plugin improved: added support for the formatted text;
  • Fixed issue appears within Math Region if one presses buttons 2*3' - Cursor have wrong position after last symbol is inserted;
  • Fixed issue when definition operator did not appeared for some functions when user pressed "=" operator for undefined expression;
  • Built-in functions usage improved;
  • Evaluation and File Types plugins improved;
  • Ability to work with different functions styles improved;
  • Fixed numerical issue with fractional powers of matrices;
  • Critical error fixed, appears when user presses ';' keyboard button using the program with options: '.' as a Decimal Symbol and ',' as a Arguments separator;
  • Fixed error appeared when all format options of the Math region lost on spacebar enter to convert Math region to Text region;
  • Fixed issue when installed copy of the program represents as a portable version;
  • Fixed issue when if(..) function cannot be used to plot a graphs;
  • Fixed numeric and symbolic issues of comparing strings;
  • Symbolic engine trigonometric simplification error fixed: "-4*sin^2*α+5-4*cos^2*α";
  • Fixed infinite loop problem when user defines recursive function: sin(x):=sin(2*x); sin(x):=sin(3*x);
  • Fixed error with changing History steps for Plot Regions;
  • Multi-threading evaluations improved when calculation in progress for more then one worksheet;
  • Program now shows an error on symbolic evaluation of expression contains function with empty name;
  • Teamwork Session: Fixed error with wrong delimiters sent to client on session join;
  • Teamwork Session: Critical error fixed appears sometimes on worksheet recalculating;
  • Teamwork Session: Fixed error when Optimization and Disable Evaluation properties cannot be sent to client;
  • Refactoring.
System requirements
  • Handheld:
    Framework: .NET Compact Framework 2.0 cab (5,33МБ), zip (1,99МБ)
    Compatibility: Pocket PC 2002, WM 2003, WM 2003 SE, WM 5, WM 6, WM 6.1, WM 6.5, full VGA support, all PPC's, Comunicators and smartphones.
  • Desktop (Windows):
    Framework: .NET Framework 2.0
  • Desktop (Linux):
Interface languages
Desktop и Handheld (34 languages):
  • [BUL] Bulgarian / Български
  • [CAT] Catalan / Català
  • [CZE] Czech / Čeština
  • [DAN] Danish / Dansk
  • [DUT] Dutch / Nederlands
  • [ENG] English / English
  • [FAS] Persian / فارسی
  • [FIN] Finnish / Suomi
  • [FRE] French / Français
  • [GER] German / Deutsch
  • [GRE] Greek / Ελληνικά
  • [HEB] Hebrew / עברית
  • [HUN] Hungarian / Magyar
  • [ITA] Italian / Italiano
  • [LAV] Latvian / Latviešu
  • [LTH] Lithuanian / Lietuvių
  • [NOR] Norwegian / Norsk
  • [POL] Polish / Polski
  • [RON] Romanian / Română
  • [RUS] Russian / Русский
  • [SCR] Croatian / Hrvatski
  • [SLK] Slovak / Slovenčina
  • [SPA] Spanish / Español
  • [SWE] Swedish / Svenska
  • [TUR] Turkish / Türkçe
  • [UKR] Ukrain / Українська
    Free Download
    * For installation of the program from PPC it is necessary to transfer a file on Your handheld computer (for example, with MS ActiveSync) and start it there with Your file manager.
    Tutorial
    Other files
    Edited by user 10 January 2012 11:58:17(UTC)  | Reason: Not specified
  • thanks 1 user thanked Andrey Ivashov for this useful post.
    on 10/01/2012(UTC)
    Offline oscampo
    #2 Posted : 10 January 2012 14:58:21(UTC)
    oscampo
    Colombia
    Excellent work and very impressive improvements. Thank you!
    Guest (2)
