Russia ☠forever Viacheslav N. Mezentsev |
8 users thanked uni for this useful post.
on 21/06/2019(UTC), on 21/06/2019(UTC), on 21/06/2019(UTC), on 21/06/2019(UTC), on 22/06/2019(UTC), on 22/06/2019(UTC), on 22/06/2019(UTC), on 24/06/2019(UTC)
Thanks Viacheslav. Something unusual: can't reply "Quote" on this one. Would be interesting the plugin could be added SS 6179 ? Cheers ... Jean
The API has changed significantly in recent versions of the program. I think it makes sense to create a new plugin using the new changes in API. I will try to add support for most of the chart types. |
4 users thanked uni for this useful post.
Joined: 28/08/2014(UTC) Posts: 1,367 Was thanked: 826 time(s) in 523 post(s)
Originally Posted by: uni ... I will try to add support for most of the chart types. ... Hi uni. Thanks for the new plugin. Two things. One, the link in the "credits" it's broken. This is, not the text for the sources, but the link in the html. Also, in the meantime, can you provide just one or two very simple examples? I don't know how to insert the ms chart. Best regards. ALvaro.
Updated. Changes: - serialization added; - some default chart properties changed. How to insert: There is still a lot of work to improve component stability. Edited by user 25 June 2019 22:22:00(UTC)
on 25/06/2019(UTC), on 26/06/2019(UTC)
