Joined: 28/11/2017(UTC) Posts: 20 Location: Pisa Was thanked: 2 time(s) in 2 post(s)
The Table region PlugIn is very useful (thanks Davide!) and nice, but I wonder if there is any way to show a calculated value in between other text in the caption (or footnote) field. I see that there are special keys (%T, %S, %R etc.) to show some particular numbers in the caption, it would be interesting and useful to have, let's say, %V(varname) to show the value of a variable of the sheet.
Does anyone know a workaround or maybe this could be a future additional feature?
Thanks Marco
Jean, thanks for your help, your examples always have interesting hints. However, what I would like to do is something like this below: I would like to show a variable value in place of "xxxx" in the caption of the above table. I have not found any way to do that and probably it is not possible, for the actual version of this plug-in. Any suggestion welcome. Thanks Marco
Originally Posted by: MBernacca I would like to show a variable value in place of "xxxx" in the caption of the above table.
... as live variable probably not possible. If you say and tabulate the calculated values are normalized at some speed xxx RPM then write it as such All data normalized @ 3600 RPM
You could just place a formatted label region over the caption . This is a bit weird but it works. Use the context menu to switch off input and border. label.sm (5kb) downloaded 39 time(s).In newer SMath versions, you can also use a standard text region with an embedded formula, where you can suppress input display and even specify a unit. Edited by user 29 January 2020 20:03:11(UTC)
