Hi I am new to Smath
I want to select few variables. eg If P=1, then X = 1, Y=2 & Z=3 If P=2, then X = 4, Y=1 & Z=7 If P=3, then X = 3, Y=2 & Z=1
I want to use X, Y & Z values based on the selected value of P
Thanks in advance
Thanks Jean
I will try this one
Using "cases" function. cases_ex.sm (90kb) downloaded 10 time(s).Edited by user 30 April 2020 14:46:31(UTC)
1 user thanked ndtma for this useful post.
Originally Posted by: Praveenpk I will try this one Page1 if_oterwise.sm (5kb) downloaded 10 time(s).
Joined: 30/03/2020(UTC) Posts: 31 Location: KU Was thanked: 3 time(s) in 2 post(s)
If you want to use the variable names X,Y,Z a simple data:mat(1,4,3,2,1,2,3,7,1,3,3) mat(X,Y,Z,3,1):col(data,p) will do the job. you can also use a vector XYZ XYZ:el(data,range(1,3),p) and its components i=1..3 el(XYZ,i) -- copy code to sheet Edited by user 30 April 2020 17:35:07(UTC)
1 user thanked hawe for this useful post.
Generalize demo. No sweat to capture [X,Y,Z] from n*m matrix. Page5 Generalize.sm (6kb) downloaded 20 time(s).
