Joined: 16/05/2020(UTC) Posts: 2 Was thanked: 2 time(s) in 1 post(s)
A function that improves the normal range(). This is almost a normal range(), but it can plot a span from non-integers with a configurable step. Moreover, any numbers can be substituted inside the interval. There are examples inside. Get Range 3.sm (719kb) downloaded 34 time(s).You can put the file in the snippet folder to quickly add it to any project. I don't know much English, so I write through a translator. Russian forum is closed so I write here.Edited by user 16 May 2020 20:49:14(UTC)
2 users thanked birikov for this useful post.
on 16/05/2020(UTC), on 16/05/2020(UTC)
Interesting, but can't see any use in real project. idx.sm (7kb) downloaded 20 time(s).
Joined: 15/04/2012(UTC) Posts: 1,989 Was thanked: 1128 time(s) in 724 post(s)
As I understand, the main objective is to have ranges with custom extra values. Yet, given the size of the procedure, it must be much smarter than this: re.sm (4kb) downloaded 11 time(s). |
Originally Posted by: mkraska As I understand, the main objective is to have ranges with custom extra values. Yet, given the size of the procedure, it must be much smarter than this: re.sm (4kb) downloaded 11 time(s). Wow, this is cool and so easy. I didn't realize it before. And I understood why this option did not suit me. I needed to build a range that could start with a non-integer and end with a non-integer, but the main step should be an integer. That is, so that you can start with 0.99, and then the step becomes an integer. At the same time, it was necessary to change the step. And inside non-integers as a bonus, just because the sorting function can do it. There is probably a simpler solution, but I haven't found it. I just needed a similar feature at the University and decided to share it here. Maybe it will be useful to someone.
Originally Posted by: birikov I needed to build a range that could start with a non-integer and end with a non-integer, but the main step should be an integer. That is, so that you can start with 0.99, and then the step becomes an integer. At the same time, it was necessary to change the step. And inside non-integers as a bonus, just because the sorting function can do it. There is probably a simpler solution, but I haven't found it. I just needed a similar feature at the University and decided to share it here. Maybe it will be useful to someone. This might be a first approach... re1.sm (4kb) downloaded 19 time(s). |
