Offline Alvaro Gavilán
#1 Posted : 31 May 2020 03:46:04(UTC)
Alvaro Gavilán
Paraguay
Was thanked: 25 time(s) in 16 post(s)
Do you know why or what could be the problem for SMath not translating properly a dy/dx. I need to write these operators in Maxima to solve a differential equation...
Thanks in advance,
Differentiation.sm (10kb) downloaded 7 time(s).
Edited by user 31 May 2020 06:16:46(UTC)  | Reason: Not specified
#2 Posted : 31 May 2020 04:23:02(UTC)
Alvaro Gavilán
Paraguay
I have found a workaround, with eval_string() from Maxima.
Differentiation.sm (14kb) downloaded 11 time(s).
Offline Razonar
#3 Posted : 31 May 2020 05:55:54(UTC)
Razonar
Uruguay
Was thanked: 826 time(s) in 523 post(s)
Hola tocayo. Is this the problem?: always it is diff(y,x)=0, but diff(y(x),x) remains unevaluated and is the correct form to express the derivative of a function.
on 31/05/2020(UTC)
#4 Posted : 31 May 2020 06:16:30(UTC)
Alvaro Gavilán
Paraguay
Hola tocayo, muchas gracias!
Problem solved:
#5 Posted : 31 May 2020 14:12:03(UTC)
You are mixing two CAS that will not pass QA [Quality Assurance].
My understanding is that what was usable from Maxima is native in Smath.
Smath native derivative operator works from book library.
sin(x), ln(x), exp(x) ... OK
Gamma(x), erf(x) ... zap. We have them otherwise.
Differentiation.sm (18kb) downloaded 25 time(s).
#6 Posted : 31 May 2020 16:29:55(UTC)
Alvaro Gavilán
Paraguay
Thank you Jean, I am trying to test some symbolic solutions of differential equations just for a course video where I show some of the capabilities that are not present in Mathcad (Prime).
#7 Posted : 31 May 2020 18:42:32(UTC)
Very few DE have symbolic solutions, unless from Handbooks.
Few of them are available in Smath ... will be back on that.
#8 Posted : 01 June 2020 00:46:56(UTC)
If Mathcad Prime does not solve those attached ... Oh !
Cheers ... Jean.
ODE Symbolic 4_Flies.sm (131kb) downloaded 21 time(s).
ODE Symbolic Bernoulli.sm (12kb) downloaded 16 time(s).
ODE_Laplace 1rst [Type 2].sm (23kb) downloaded 11 time(s).
ODE Symbolic Verhulst [Logistic].sm (26kb) downloaded 9 time(s).
ODE Symbolic Lambert.sm (22kb) downloaded 10 time(s).
ODE_Laplace 1rst [Type 1].sm (25kb) downloaded 12 time(s).
ODE_Laplace 2nd [Type 3].sm (35kb) downloaded 9 time(s).
ODE Symbolic Eiffel.sm (22kb) downloaded 11 time(s).
