I have the following variables: d (density) in gm per cm*cm*cm, s (area) in cm*cm, n (atoms per ml) = density*Avagadros number* Moles per gram
Units of D are gm/(cm*cm*cm) Units of s are cm*cm Units of n are calculated by SMATH to be gm/(m^3 kg) (ok conceptually, would like to get rid of grams per kilogram) How do I get that to 1/(cm^3)? I've tried lots of unit operations and I'm stymied.
Similarly, I calculate t=1/(n*s), results should be in cm, but SMATH calculates (kg * cm / gm). Is there a way to get this normalized to just cm?
Thank you!
Construct the project in the SI unit system. BTW, density is what = nothing/anything. "weight density" has meaning, in SI kg/m³
Joined: 15/04/2012(UTC) Posts: 1,989 Was thanked: 1128 time(s) in 724 post(s)
Originally Posted by: Brian729 I have the following variables: d (density) in gm per cm*cm*cm, s (area) in cm*cm, n (atoms per ml) = density*Avagadros number* Moles per gram
Thank you!
Sure that gm is correct for gram? Used to be in very old SMath versions. Now it is g. It should be obvious from the dynamic assistant whether a given unit is available or not. |
Joined: 28/08/2014(UTC) Posts: 1,367 Was thanked: 826 time(s) in 523 post(s)
Originally Posted by: mkraska ... Sure that gm is correct for gram? Used to be in very old SMath versions. Now it is g. It should be obvious from the dynamic assistant whether a given unit is available or not. Hi. This is a picture about what Martin says: Best regards. Alvaro.
The Engineering form of Avogadro P*V=Z*n*R*T Where 'Z' compressibility factor from source.
