  Rank: Administration Groups: Administrators
Joined: 7/11/2008(UTC) Posts: 751   Was thanked: 218 time(s) in 120 post(s)
New SMath Studio 0.92 Stable available Absolutely free mathematical program with "paper"-like interface and numerous computing features (now with integrated mathematical reference book). SMath Studio Desktop on the Desktop (Windows) SMath Studio Desktop on the Desktop (Linux) Last changes - Printing bounds displaying implemented directly on the worksheet;
- Printing improved: added ability to specify pages to print, print current page only (the page where cursor is located) or to print a selection;
- Context Menu items now also added to Edit button of the Main Menu;
- Graph animations performance improved up to 20%;
- Calculations performance improved;
- Program will now cancel any try to copy selected regions to the same location as initial using Ctrl key;
- Current Region (Region with cursor inside) is now always shown on top (z-index) of others;
- Hiding of the error when removing a region fixed;
- Improved showing of the current error status of the Region;
- Print preview dialog improved;
- Plot Region error handling improved;
- Added internal support for color and alignment of the Header and Footer text on print out;
- Fixed critical error appeared when pressing on the Graph related buttons from Plot Math Panel if no Plot Region focused;
- Fixed math panels issues appeared when screen DPI not equal to 96;
- Fixed infinite loop issue appears for complex functions when math error occurs inside;
- Fixed blinking of the Separator Region on worksheet horizontal scroll;
- Several issues fixed appeared when non-standard Worksheet's scaling used;
- Fixed drawing issue appeared on Grid displaying property changed when two or more Worksheets are shown side by side within one instance of the program;
- Fixed error of the Symbolic Library appears when working with Units for expressions with numeric optimization;
- Changing of the latin symbol to greek one or vice versa using Ctrl+G repaired for Text Region;
- Fixed error appears on printing of the large Regions;
- Fixed critical error on program startup when any of snippets has no Title set by File > Properties;
- Couple of issues fixed regarding copying of content close to the collapsed Area Region;
- Fixed error popup animation issue (animated twice);
- Fixed issue appeared some times on pasting content from clipboard: region was not visible till any other user's action;
- Language files updated;
- Refactoring.
Framework: .NET Framework 2.0
- Desktop (Linux):
Interface languages Desktop и Handheld (34 languages): [BEL] Belarusian / Беларуская [BUL] Bulgarian / Български [CAT] Catalan / Català [CHS] Chinese (Simplified) / 简体中文 [CHT] Chinese (Traditional) / 簡體中文 [CPP] Portuguese (Brazil) / Brazil (Português) [CZE] Czech / Čeština [DAN] Danish / Dansk [DUT] Dutch / Nederlands [ENG] English / English [FAS] Persian / فارسی [FIN] Finnish / Suomi [FRE] French / Français [GER] German / Deutsch [GRE] Greek / Ελληνικά [HEB] Hebrew / עברית [HUN] Hungarian / Magyar [IND] Indonesian / Bahasa Indonesia [ITA] Italian / Italiano [LAV] Latvian / Latviešu [LTH] Lithuanian / Lietuvių [NOR] Norwegian / Norsk [POL] Polish / Polski [POR] Portuguese / Português [RON] Romanian / Română [RUS] Russian / Русский [SCC] Serbian (Latin) / Srpski [SCR] Croatian / Hrvatski [SLK] Slovak / Slovenčina [SPA] Spanish / Español [SRP] Serbian (Cyrillic) / Српски [SWE] Swedish / Svenska [TUR] Turkish / Türkçe [UKR] Ukrain / Українська
Free Download
Note: No SMath Studio Handheld 0.92 release will be introduced. Please use the latest stable handheld version (0.90).
Tutorial SMath Studio tutorial by Bernard Liengme.
SMathPrimer.pdf (Date: 11.11.2011. File size: 2.06MB) - to open in Adobe Acrobat Reader
Other files SMath Studio icons ( ) of all available sizes (16x16, 24x24, 32x32, 48x48, 64x64, 96x96, 128x128, 256x256) in PNG format.
Edited by user Saturday, February 25, 2012 11:08:49 PM(UTC)
 3 users thanked smath for this useful post.
on 2/25/2012(UTC), on 2/26/2012(UTC), on 2/27/2012(UTC)
