Hello, It seems that the imaginary unit (i = sqrt(-1)) is treated differently in v0.92 comparing to v0.91. It seems it is not allowed as a function argument in the function definition. Example: Accompanied file i-funargument.smRegards, Radovan |
Yes. This is by design: "i" (imaginary part) cannot be used as an attribute of the function definition anymore. This was required to fix the situation we had in earlier SMath Studio versions: Regards.
Thank you Andrey, Yes, I remembered now the discussion about the imaginary unit as a function argument. Regards, Radovan Edited by user 27 February 2012 23:30:31(UTC)
