SMath Studio Forum
Download SMath Studio
Archive
Stable: SMath Studio 0.99.7561 (13 September 2020)
They talk about us
Smath is easy to use tool and its is freeware.I used for engineering calculations instead of easing excel. Its a time saver.
more...
by Naresh varikuntla
Mi programa favorito para calculos matematicos en general
more...
by Joan Enric Coca
Excelente programa, es como tener el clásico papel y lápiz pero ahora con un potente calculador y con muchas funciones, me gustaría que tenga opciones de base de datos para poder usarlo en la ciencia Estadística.
more...
by Christian Minaya
- Desktop (Linux):
- [BUL] Bulgarian / Български
- [CAT] Catalan / Català
- [CZE] Czech / Čeština
- [DAN] Danish / Dansk
- [DUT] Dutch / Nederlands
- [ENG] English / English
- [FAS] Persian / فارسی
- [FIN] Finnish / Suomi
- [FRE] French / Français
- [GER] German / Deutsch
- [GRE] Greek / Ελληνικά
- [HEB] Hebrew / עברית
- [HUN] Hungarian / Magyar
- [ITA] Italian / Italiano
- [JPN] Japanese / 日本語
- [KOR] Korean / 한국어
- [LAV] Latvian / Latviešu
- [LTH] Lithuanian / Lietuvių
- [NOR] Norwegian / Norsk
- [POL] Polish / Polski
- [RON] Romanian / Română
- [RUS] Russian / Русский
- [SCR] Croatian / Hrvatski
- [SLK] Slovak / Slovenčina
- [SPA] Spanish / Español
- [SWE] Swedish / Svenska
- [TUR] Turkish / Türkçe
Introduction of the use of SMath Studio by Gilberto E. Urroz, Ph.D., P.E. Other files SMath Studio icons ( ) of all available sizes (16x16, 24x24, 32x32, 48x48, 64x64, 96x96, 128x128, 256x256) in PNG format.
on 14/09/2020(UTC), on 14/09/2020(UTC), on 14/09/2020(UTC), on 14/09/2020(UTC), on 14/09/2020(UTC), on 14/09/2020(UTC), on 14/09/2020(UTC), on 15/09/2020(UTC), on 24/09/2020(UTC)
Underline white space is fixed, almost. I have tried with some major fonts I possess. Some fonts still have glitches. I wouldn't mind or notice this if courier new wouldn't have this bug. Because it was one and only font on older releases, most of my documents have courier new as solitary font. Regards
Thank you. Will try to handle it asap.
The interactive tutorial "Getting Started with SMath Studio" has been adjusted to version 7561. It is available in the extension manager as "example" in three languages: German, English, Polish. Work on Portugese is in progress. The guide has a section on symbolic equation solving with Maxima. It is tested with Maxima 5.44.0. |
4 users thanked mkraska for this useful post.
on 16/09/2020(UTC), on 21/09/2020(UTC), on 24/09/2020(UTC), on 29/09/2020(UTC)
The german handbook has been updated to version 7561. It is available in the extension manager as "handbook". |
I prepared a new Unofficial distribution with plugins, yet I can't upload it. The error message says The page was not displayed because the request entity is too large. The zip file is 98 MB. If disk space is tight, I'd be fine with deleting older versions. |
The interactive tutorial "Getting Started with SMath Studio" has new translations: Catalan and Spanish, many thanks to Prof. Jose Manuel Portolés Flaj. It is now available in the extension manager as "example" in 5 languages: German, English, Polish, Catalan and Spanish. |
Originally Posted by: mkraska I prepared a new Unofficial distribution with plugins, yet I can't upload it. The error message says
About a Month ago I've setup a new server and we have enough disk space now. I will check why it happens. Thank you for your work!
Originally Posted by: mkraska The zip file is 98 MB. If disk space is tight, I'd be fine with deleting older versions. Fixed. Files Manager supports files up to 150 MB now. Please try again.
Originally Posted by: Andrey Ivashov Originally Posted by: mkraska The zip file is 98 MB. If disk space is tight, I'd be fine with deleting older versions. Fixed. Files Manager supports files up to 150 MB now. Please try again. Thanks for fixing the problem and providing the space. The distribution is updated now including the PDF handbook (German) and the interactive tutorial (Examples> Getting Started) in German, English, Polish, Spanish and Catalan. The link in my signature points to the wiki page of the portable distribution. |
В старых версиях программы (довольно старых) когда для какой либо формулы включал опцию "Запретить вычисление", то при последующей печати в pdf или картинку эта формула была просто слегка затенена, но вполне читаема. Сейчас же эти формулы совершенно нечитаемы. Можно это как то исправить?
Originally Posted by: genf В старых версиях программы (довольно старых) когда для какой либо формулы включал опцию "Запретить вычисление", то при последующей печати в pdf или картинку эта формула была просто слегка затенена, но вполне читаема. Сейчас же эти формулы совершенно нечитаемы. Можно это как то исправить? Каким PDF принтером вы пользуетесь? Я воспроизвести такие проблемы у себя не смог. Учитывая, что известные мне PDF принтеры выводят изображение нормально и что в программе давно не менялось ничего связанного с отрисовкой формул мне кажется что проблема в том PDF принтере, что вы используете.
Originally Posted by: Andrey Ivashov Каким PDF принтером вы пользуетесь? Я воспроизвести такие проблемы у себя не смог. Учитывая, что известные мне PDF принтеры выводят изображение нормально и что в программе давно не менялось ничего связанного с отрисовкой формул мне кажется что проблема в том PDF принтере, что вы используете.
Уже долгое время (лет 9-10) пользуюсь принтером pdf24. Возможно в каком то из обновлений этого принтера что то было изменено. На работе других программ не отразилось. Какой pdf принтер посоветуете, чтобы корректно печаталось? Буду им пользоваться тогда при печати из Smath Studio.
Originally Posted by: genf Уже долгое время (лет 9-10) пользуюсь принтером pdf24. Возможно в каком то из обновлений этого принтера что то было изменено. На работе других программ не отразилось. Какой pdf принтер посоветуете, чтобы корректно печаталось? Буду им пользоваться тогда при печати из Smath Studio.
С помощью «PDF Files Plugin» вы можете экспортировать напрямую как PDF. |
Originally Posted by: genf Originally Posted by: Andrey Ivashov Каким PDF принтером вы пользуетесь? Я воспроизвести такие проблемы у себя не смог. Учитывая, что известные мне PDF принтеры выводят изображение нормально и что в программе давно не менялось ничего связанного с отрисовкой формул мне кажется что проблема в том PDF принтере, что вы используете.
Уже долгое время (лет 9-10) пользуюсь принтером pdf24. Возможно в каком то из обновлений этого принтера что то было изменено. На работе других программ не отразилось. Какой pdf принтер посоветуете, чтобы корректно печаталось? Буду им пользоваться тогда при печати из Smath Studio. В Windows 10 установлен Microsoft Print to PDF принтер. В последнее время я только им и пользуюсь. Рекомендую.
Я собственно почему пользуюсь именно pdf24. Мне как таковой именно pdf формат не нужен. Мне нужны картинки формата png, которые вставляю в Word, где есть рамка по внутренним стандартам. Можно конечно пользоваться другим принтером или встроенным конвертером, получать pdf, а уже из него извлекать png. Сейчас скриншоты делаю из предварительного просмотра ... но чтобы не было таких костылей хочу уйти от использования "запрет вычислений".
In order to copy expressions to word, you can just select the regions, copy and paste them. Works very well also in the bug tracing system editor, unfortunately not here in the forum.
Here I usually save the sheet as png (file> save as> png) and upload it to the forum. Thus, usually there is no need for screenshots. |
on 27/09/2020(UTC), on 28/09/2020(UTC)
Я собственно почему пользуюсь именно pdf24. Мне как таковой именно pdf формат не нужен. Мне нужны картинки формата png, которые вставляю в Word, где есть рамка по внутренним стандартам. Можно конечно пользоваться другим принтером или встроенным конвертером, получать pdf, а уже из него извлекать png. Сейчас скриншоты делаю из предварительного просмотра ... но чтобы не было таких костылей хочу уйти от использования "запрет вычислений". Тогда всё ещё проще: просто выделите и скопируйте нужные формулы и вставляете их в Word. SMath Studio создаст высококачественные изображения для формул автоматически и никаких промежуточных действий не потребуется.
Originally Posted by: mkraska In order to copy expressions to word, you can just select the regions, copy and paste them. Works very well also in the bug tracing system editor, unfortunately not here in the forum.
Here I usually save the sheet as png (file> save as> png) and upload it to the forum. Thus, usually there is no need for screenshots. Originally Posted by: Andrey Ivashov Тогда всё ещё проще: просто выделите и скопируйте нужные формулы и вставляете их в Word. SMath Studio создаст высококачественные изображения для формул автоматически и никаких промежуточных действий не потребуется.
Вот не знал об этом. То что нужно и значительно быстрее Огромное Спасибо! Единственное не нужно выделять при этом "Области". Edited by user 28 September 2020 10:01:54(UTC)
SMath Studio Forum
Archive
