16 Pages«<13141516>
Offline netsonicyxf
#281 Posted : 24 March 2020 17:10:39(UTC)
netsonicyxf
Was thanked: 2 time(s) in 2 post(s)
Originally Posted by: netsonicyxf Go to Quoted Post
I have a portable version of Smath 0.99.7251. The Maxima is under D:\Program Files\Math Tools\SMath Studio\extensions\plugins\44011c1e-5d0d-4533-8e68-e32b5badce41\1.98.7100.23756\
I put the above path into insert->settings, but it show "Cannot find maxima.bat"
Did you install Maxima? If not, follow the link in my signature and see the instructions for installing and configuring Maxima. The plugin just provides the interface.
Thanks. I installed Maxima 5.42.2.
But still can't get result. SM file attached.
maxima.sm (3kb) downloaded 31 time(s).
Edited by user 25 March 2020 04:22:45(UTC)  | Reason: Not specified
#282 Posted : 24 March 2020 19:01:31(UTC)
Why so much trouble for ordinary stuff vs Smath Native ?
Offline netsonicyxf
#283 Posted : 25 March 2020 04:22:03(UTC)
netsonicyxf
Thanks Jean, but can't get result either.
error:"x not defined"
maple.sm (3kb) downloaded 24 time(s).
Offline CBG
#284 Posted : 25 March 2020 06:32:16(UTC)
CBG
put the optimization to symbolic or none
#285 Posted : 25 March 2020 12:04:40(UTC)
You have to set Optimization to Symbolic or None to display symbolic results. You can also press Ctrl+. instead of = to get symbolic results from an expression.
@Jean: maple isn't SMath native, you see that if you try it in the cloud version. Also, the legal/license status of the embedded maple executable has never been clarified. There might be people who care about this.
#286 Posted : 25 March 2020 15:46:52(UTC)
YES Martin. On the other hand, Maple is the former Macsyma
joint venture MIT/UT [University of Toronto].
Hard to legal/license to freeware Smath.
The very core Maple is largely due to Angot ancestor.
Thanks Martin ... Cheers/Jean
#287 Posted : 08 October 2020 13:00:15(UTC)
This is an example on how to control the assumptions used for symbolic integration in Maxima.
1-2-4 Widerstandskrafte.sm (13kb) downloaded 42 time(s).
on 08/10/2020(UTC),  on 10/10/2020(UTC)
#288 Posted : 11 October 2020 02:52:49(UTC)
Get more from less ... typical.
Offline Ber7
#289 Posted : 23 November 2020 22:28:27(UTC)
Ber7
Israel
Was thanked: 520 time(s) in 288 post(s)
Animation in Maxima
Плагин Maxima не имеет встроенной возможности анимации.
Для создания анимации использовалась программа
https://en.smath.com/for...animation.aspx#post48012
Для записи Gif файла использовалась программа GifCam.
povorot1.sm (75kb) downloaded 32 time(s).
SpiralMaxima.sm (46kb) downloaded 28 time(s).
thanks 3 users thanked Ber7 for this useful post.
on 23/11/2020(UTC),  on 24/11/2020(UTC),  on 25/11/2020(UTC)
Offline Ber7
#290 Posted : 23 November 2020 22:35:47(UTC)
Ber7
Israel
Visualization of animation steps
Slider.sm (160kb) downloaded 27 time(s).
thanks 2 users thanked Ber7 for this useful post.
#291 Posted : 24 November 2020 00:15:12(UTC)
Originally Posted by: Ber7 Go to Quoted Post
Animation in Maxima
Very nice. Here is a version with absolute variables (names starting with ~, not easy to input with german keyboard) for execution counter. BTW, the original version reads temp storage before it is written. This throws an error similar to what would happen if I had not checked for a being undefined.
povorot1_kr.sm (76kb) downloaded 28 time(s).
on 24/11/2020(UTC)
Offline Ber7
#292 Posted : 24 November 2020 00:35:41(UTC)
Ber7
Israel
Vibrations of a rectangular membrane
Vibration Restangular Membrane.sm (185kb) downloaded 43 time(s).
thanks 1 user thanked Ber7 for this useful post.
on 24/11/2020(UTC)
Offline Ber7
#293 Posted : 24 November 2020 01:10:35(UTC)
Ber7
Israel
Thanks a lot, Martin. Wonderful! I was not aware of the IsDefined function.
Edited by user 24 November 2020 01:24:58(UTC)  | Reason: Not specified
#294 Posted : 24 November 2020 17:09:18(UTC)
Thanks Champions: Martin, Ber7
Offline Ber7
#295 Posted : 24 November 2020 23:37:40(UTC)
Ber7
Israel
Vibrations of a circular membrane.The general case
https://en.smath.com/for...ations-of-membranes.aspx
CircleAntisiimmetr.sm (253kb) downloaded 29 time(s).
Edited by user 24 November 2020 23:43:35(UTC)  | Reason: Not specified
Offline alyles
#296 Posted : 07 May 2021 03:12:01(UTC)
alyles
United States
Originally Posted by: Andrea993 Go to Quoted Post
We really need a linux port
I agree. Maybe, just an adjustment of the command line for establishing the socket connection is required. Under Windows I use
maxima-installation-path/bin/maxima.bat -l sbcl -s <port number>
This requires
- the .net socket stuff and process control to work under mono,
- a unicode-proof lisp compiler to be installed (which accepts utf-8 socket encoding), under win the only one is steel bank common lisp (SBCL).
Also, I need to know the name of the maxima process for detection of active maxima processes via System.Diagnostics.Process.GetProcessesByName(name). This is required to identify the pid for later kill. Under windows this might be "maxima" or "lisp" or "sbcl". This has changed over the years and may be different under linux.
The plugin might work even as it is, if the maxima startup script is renamed to maxima.bat.
Any information from the linuxing SMatheers is welcome.
BTW, there is a maxima build for android as well...
EDIT: It would also help, if someone could explain me how to build and debug the plugin under Linux. Under Win, I use VS 2015 with the project as found in the SVN repository. Otherwise I need to blindly make changes under win and install and test under linux. This would be a huge drawback compared to the win-only workflow, where compiling and running SMath with the new build in the debugger is just a push of a single button...
Bringing up this topic again. Has there been any progress on this?
Is this at all helpful for building the plugin in linux?
https://dotnet.microsoft...llo-world-tutorial/intro
Edited by user 07 May 2021 03:13:49(UTC)  | Reason: Not specified
#297 Posted : 07 May 2021 11:36:07(UTC)
This requires
There is no progress from my side. Also, for me, there is no chance of digging into it for at least one more year. If someone wants to do that now, I am ready to help. Yet I think that the plugin is merely a demonstrator of what could be done. It lacks a systematic and clean approach, due to lack of proper knowledge on SMath, Maxima and C# internals. It definitely requires a lot of refactoring or re-design from scratch before extending it.
Offline pk_mechanical_eng
#298 Posted : 13 May 2021 21:44:42(UTC)
pk_mechanical_eng
Hi Guys,
I'am using Smath for quite a while and already tried to use the Maxima plugin several times without any success.
I was able to do the setup as shown here: https://en.smath.com/for...t2078_Maxima-Plugin.aspx
But unfortunately in Smath the Int() function for symbolic integration never works. I'm pretty sure that I'm missing a little part. Can anyone help me please?Help smilie
Example:
When I do define x I get the following error
And when I do assign something else than a number i get:
Edited by user 14 May 2021 09:46:00(UTC)  | Reason: Not specified
#299 Posted : 13 May 2021 23:05:17(UTC)
Originally Posted by: pk_mechanical_eng Go to Quoted Post
Hi Guys,
But unfortunately in Smath the Int() function for symbolic integration never works. I'am pretty sure that I'am missing a little part. Can anyone help me please?Help smilie
Example:
This is because you use numeric optimization (context menu). If you expect symbolic results, use symbolic optimization ("none" also works, it shows the result from Maxima without further processing by SMath).
When I do define x I get the following error Wallbash
The error message is correct. The integration variable must be unassigned.
Edited by user 13 May 2021 23:07:00(UTC)  | Reason: Not specified
#300 Posted : 14 May 2021 02:03:57(UTC)
... but you have missed the best from Generous Smath Community.
1. Always/first plot the integrand.
2. You integrate over a ranged variate.
3. maple is delivered with native Smath.
Guest (2)
Similar Topics
Error implementing ToolboxGroup for the maxima plugin (Questions)
by fakemoses 31/07/2023 20:09:47(UTC)
Maxima Plugin Feedback Survey: Share Your Ideas and Report Bugs (Feature Requests)
by fakemoses 16/06/2023 13:27:33(UTC)
MAXIMA PLUGIN expand (Questions)
by Angel695 21/05/2023 10:43:40(UTC)
Solve Function Stuck (46/47) with Maxima Plugin (Questions)
by Albedo 30/08/2022 05:24:23(UTC)
[Maxima Plugin] Text exportation issue (Questions)
by SteelCat 11/01/2022 12:47:31(UTC)
Maxima Plugin problem (Bugs & Problems)
by FT_PENG 23/12/2021 23:49:19(UTC)
Text characters not passing correctly to Maxima plugin (Bugs & Problems)
by gurro 15/08/2021 00:14:03(UTC)
[Maxima Plugin] is a custom Maxima function call-able in SMath (Questions)
by 007.000 22/05/2018 13:06:49(UTC)
[Maxima Plugin] least common multiple (Questions)
by 007.000 22/05/2018 12:13:20(UTC)
news for Maxima Plugin (Questions)
by oscampo 27/01/2016 18:39:35(UTC)
Maxima plugin error (Bugs & Problems)
by olik 30/11/2015 10:17:28(UTC)
16 Pages«<13141516>
