Mi programa favorito para calculos matematicos en general
more...
by Joan Enric Coca
As a civil engineer, over the years I have frequently used MathCAD for not only performing but also documenting calculations. With PTC dropping perpetual licensing, my recommendation to all the junior engineers I train is to give SMath Studio a serious look. While not a turnkey replacement for MathCAD, it provides most of the functionality and power at an incredible price. Already a wonderful program filling a key niche spot between a numerical calculator like Octave, and a CAS like Maxima, the expanding plugin and 3rd party development is on the rise and this project's future keeps getting even brighter. Much consideration must be given by any engineer or business before they settle on a software for adopting into the workflow. Although not open-source in the strictest sense, the development community is similar to what you would find in any first class OSS software project. The current owner of the SMath Project has also agreed to release the source code under open source license should he not be able to continue the project. So do not let the cost (your time) of learning SMath Studio and migrating your MathCAD computation sheets scare you. This project is here to stay.
more...
by Michael Fuller, P.E., PMP
I am using it everyday for my professional work. Thank you so much!
more...
by Tien Nguyen
on 27/12/2020(UTC), on 27/12/2020(UTC), on 27/12/2020(UTC), on 28/12/2020(UTC), on 28/12/2020(UTC), on 01/01/2021(UTC)
Impressive progress, Andrey.
I think the math detection is a bit over-greedy. As soon as I type a hyphen, the preceeding word is taken as a variable name and a math region is embedded. Thus the only way to add a hyphen between two words is to embrace it with spaces and delete the spaces afterwards. I'd recommend to do the conversion when Enter is pressed. A second enter then would leave the embedded math region. |
3 users thanked mkraska for this useful post.
on 28/12/2020(UTC), on 28/12/2020(UTC), on 29/12/2020(UTC)
Thank you Martin very much for this suggestion!
I'm thinking about ways to make this detection more smart, more predictable to user and be easily cancelable (meaning it should be possible to cancel/undo it when it is done incorrectly or user wants to leave text as is). I have some thoughts about it, so yeah, this will be significantly improved.
Regards.
Hi. Thanks for the new features. BTW I can't paste in a math region with description, this is: if x:=line(something) I can't paste inside the x body if it have description. paste.sm (4kb) downloaded 12 time(s).Best regards. Alvaro.
Originally Posted by: Razonar BTW I can't paste in a math region with description, this is: if x:=line(something) I can't paste inside the x body if it have description. Hello Alvaro. Thank you! Will fix it asap.
I'm getting an unhandled exception error when copying text regions by highlighting an existing text region and using the Control key + mouse to copy it. It does continue without crashing, and I can apparently copy by highlighting and using Ctrl-C and Ctrl-V, or by using the buttons on the menu bar. So far it only seems to be the Ctrl + mouse method of copying that used to work and doesn't in this build. Formulas still can be copied and pasted that way without error. Thanks, Jason |
1 user thanked Jason McCool for this useful post.
Thank you! Originally Posted by: Jason McCool I'm getting an unhandled exception error when copying text regions by highlighting an existing text region and using the Control key + mouse to copy it. It does continue without crashing, and I can apparently copy by highlighting and using Ctrl-C and Ctrl-V, or by using the buttons on the menu bar. So far it only seems to be the Ctrl + mouse method of copying that used to work and doesn't in this build. Formulas still can be copied and pasted that way without error. The reason of this error is the same as it is in the issue
Razonar
mentioned above. Fixed now. Best regards.
