Hello and the obligatory THANK YOU for making a working symbolic math program! In MathCAD I regularly make calc sheets with input and output at the top, and the calculations collected below. For this I use the ~ tilde, which MathCAD turns into a ≡ which allows variables to be displayed above their definitions. I see here that such a feature should be available in SMath Studio, but I don't succeed getting it to work. https://en.smath.com/for...bsolute-definitions.aspxIs there something I misunderstand? I type like A ~ 5 but all I get is a text string like A~5. I did try the Alt + 0126 thing, no difference. I suspect it has something to do with the scroll menu that appears if I only type ~, but that does not seem to make much of a difference either. If I define ABC := 5 and then type ~ I can choose ABC in that menu, but from there on the behavior is the same. Does it have anything to do with my swedish keymap? To get the tilde, I use AltGr plus one of those buttons that do not generate a character immediately but waits until the next button is pressed. " ^ ~ are all generated by pressing that key plus space, SHIFT plus that key plus space, AltGr plus that key plus space.
Oh. Never mind. I accidentally found out that I need to type tilde, then define the variable which then get bolded.
Then I need to type tilde and TAB-choose the variable from the list, which also bolds the text. If not, then it's wrong.
So now it works. Great! Thanks again!
In Mathcad you have a special type of assignment, in SMath you have a special type of variable. If the variable name starts with a tilde than assignments to it are known also above the definition. In your example, you need to type ~A:5 Absolute variables are displayed in boldface. Blatt5.sm (3kb) downloaded 24 time(s). |
I understand. Thank you very much!
