#1 Posted : 06 February 2021 18:28:02(UTC)
Inst_IAPWS region 1 MostUsed.sm (185kb) downloaded 59 time(s).
Offline loha
#2 Posted : 07 February 2021 09:33:32(UTC)
loha
Dear Jean,
Impressive as usual, but too steep for my understanding... as usual too!
Are all these water saturation/pressure/enthalpy calculations directly made by you from raw data?
I don't see any of the usual water pressure formulae (Tetens, etc.) in this sheet.
#3 Posted : 07 February 2021 18:35:29(UTC)
Originally Posted by: loha Go to Quoted Post
Dear Jean,
My Bible is mostly the 1958 M.P. WUKALOWITSCH water steam booklet
in 4 languages: French, English, German, Russian.
No significant disagreement wrt IAPWS-97,
all those properties are experimental with some uncertainties.
I also consult Katmar not freeware but can be used 5 min per session 0 $.
I got lot of stuff from Bernard Spang [ChemEng].
Most of the polynomials in this document agree with Lagrange criteria ± sign.
For an unknown reason the Grand Savants have ignored Thiele.
The attached SUPPLEMENT is simply gorgeous as bar saturation.
It borrows the data points from so called source and up to execute.
In a steam circuit, measuring the temperature from pressure is much
faster than via T/C [Thermo-Couple} and more accurate unless a high
quality Pt100 thermometer is used, very fragile and slow.
Thanks Collab for your appreciation ... Jean.
Inst_IAPWS region 1 MostUsed SUPPLEMENT.sm (71kb) downloaded 18 time(s).
#4 Posted : 07 February 2021 20:31:28(UTC)
... in your document, round 'K' 6 decimals.
Inst_IAPWS region 1 MostUsed SUPPLEMENT.sm (73kb) downloaded 15 time(s).
#5 Posted : 08 February 2021 18:44:22(UTC)
Dear Jean,
Ioha,
For you curiosity, I have added two Tetens segments [brute force] not to avail.
The Lagrange poly order 9 is lot more accurate as a single function.
Water is like air, their properties don't respond to single DE,
thus the need to best piece wise approximate.
Air between -1 km ... 100 km is in 3 pieces [NASA, OACI]
Page16 Tetens.sm (46kb) downloaded 9 time(s).
Inst_IAPWS region 1 MostUsed SUPPLEMENT.sm (115kb) downloaded 10 time(s).
#6 Posted : 09 February 2021 22:28:51(UTC)
Dear Jean,
The two documents refreshed/refactored.
1. most used ... Last Lagrange replaced by a normalized rational fraction.
2. ... SUPPLEMENT refactored to extends Tetens [180 °C, 10 bar]
Given both ways saturation [bar(°C), °C(bar)].
If you have more interest in Tetens, I may look to extend a bit more.
Please, let me know. Take care ... Jean.
Inst_IAPWS region 1 MostUsed SUPPLEMENT.sm (153kb) downloaded 9 time(s).
Inst_IAPWS region 1 MostUsed.sm (194kb) downloaded 8 time(s).
#7 Posted : 10 February 2021 04:37:43(UTC)
This last brew certifies/solves Tetens [85.9 bar ... 300 °C].
Enjoy ... Jean
Inst_IAPWS region 1 MostUsed SUPPLEMENT.sm (162kb) downloaded 16 time(s).
Offline loha
#8 Posted : 10 February 2021 11:17:05(UTC)
loha
Dear Jean, I am only architect and I used Tetens' formula just to find the absolute humidity from the relative humidity from data collected from my data loggers... Your calculations are far too accurate for my needs!
However I will share my attempts at dome calculations based on Maxwell's polar polyedra and Marina Konstantatou's thesis (I have seen impressive visuals here based on just the in-built 2D and 3D graph regions)... for which you could maybe help me!
Thank you,
Laurent
#9 Posted : 10 February 2021 15:34:10(UTC)
However I will share my attempts at dome calculations based on Maxwell's polar polyhedra and Marina Konstantatou's thesis (I have seen impressive visuals here based on just the in-built 2D and 3D graph regions)... for which you could maybe help me!
Thank you,
Laurent
Laurent, please attach some data [vectors, table ...].
I can't resit data ... smoothing, fitting, surface plot, rotation.
Your stuff will delight Smath Community and we all go along so well !
Wait and see from so far away ... Jean
Offline ElSid
#10 Posted : 10 February 2021 21:02:47(UTC)
ElSid
United States
Dear Jean,
Updated my Water Vapor Saturation file. It's per ASHRAE IP units
#11 Posted : 10 February 2021 23:20:21(UTC)
... last segment in pink [255, 225, 225] pushes Tetens up to 370 °C ± 0.5 bar.
Inst_IAPWS region 1 MostUsed SUPPLEMENT.sm (168kb) downloaded 14 time(s).
