As experienced mechanical guy, this powerful tool is extremely useful for calculation for my work activities, and amazing it is free please keep working for software crown and kick expensive mathcad away!
more...
by Kelvin Liu
Très bon logiciel de calcul, avec de nombreux plugin pour tous les usages.
Une fois qu'on s'habitue, on ne peut plus s'en passer.
Je le recommande vivement.
Outre les fonction mathématiques, Il est possible d'utiliser de nombreuses bibliothèques, comme par exemple la bibliothèque Coolprop pour les données thermodynamiques, ce qui permet d'avoir un outil très évolué pour faire et expliquer des calculs très rapidement.
more...
by Vidal Silva
Amazing, well-done, useful tool. A small donation was sent your way. This small comment of praise is a follow-up.
more...
by Jason H
on 21/01/2021(UTC), on 21/01/2021(UTC), on 21/01/2021(UTC), on 21/01/2021(UTC), on 22/01/2021(UTC), on 23/01/2021(UTC)
Problem with areas. The titles disappeared
Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 125 time(s) in 82 post(s)
Originally Posted by: ElSid Problem with areas. The titles disappeared Same problem with my SM files too. Edited by user 23 January 2021 06:47:09(UTC)
Joined: 23/07/2013(UTC) Posts: 1,128 Was thanked: 509 time(s) in 339 post(s)
Originally Posted by: ndtma Originally Posted by: ElSid Problem with areas. The titles disappeared Same problem with my SM files too. They are there, but not visible unless you try to select the titles. It is same with smath book with quite sometime, maybe related to document mode, it started with build 7666. Even if you have disabled or never activated it area titles disappeared from me since document mode is released. It will be fixed soon I guess. Regards.
Originally Posted by: overlord It will be fixed soon I guess. True.
Andrey, I can no longer specify a "custom page size". I need larger than 11x17 US.
