Hello Ioan, Andrey,
"insert file" as per Mathcad "insert reference". A superb example in Mathcad is the "Fractal Display". This one page document displays any fractal by #, all calculations and related stuff done in the master work sheet ... Similarly, one could recapitulate client project ... Edu subject matters ... I Could use such a facility in Instrumentation, type the loop # and get the list of components, brush on the desired component [per say PT pressure tansmitter] and get the specification sheet.
Cheers, Jean
Joined: 09/11/2013(UTC) Posts: 32 Location: Leinster Was thanked: 4 time(s) in 4 post(s)
Joined: 28/08/2014(UTC) Posts: 1,368 Was thanked: 829 time(s) in 525 post(s)
Hi Gerard. Please, check this plugins: include and run. Best regards. Alvaro.
Thanks. I'll investigate those functions.
