Offline churichuro
#1 Posted : 28 March 2021 07:56:33(UTC)
churichuro
Mexico
Was thanked: 27 time(s) in 22 post(s)
Is it possible to enable a new operator "..."
whose function is to allow dividing
long expressions between several lines?
like this:
some_var := arg1 operator arg2 operador ...
arg3 operador arg4 etc.
x.1 := 2 + 3 + 4 ...
+ 5 + 6
x.1 = 20
Currently you can do something similar with the
key combination ctrl + Enter but it is a bit limited
I think this could be very useful, especially in the new document mode
Offline fedeghi
#2 Posted : 28 March 2021 11:58:00(UTC)
fedeghi
Was thanked: 24 time(s) in 16 post(s)
Already available, use SHIFT+Enter in the position where you want to split the line Wink
#3 Posted : 28 March 2021 15:08:36(UTC)
long expressions between several lines ?
You mean: Mathcad style ?
Was rarely used, just to recollect a long symbolic result.
Not so much useful ... explain:
the "..." is a keystroke, thus the split does not update.
In lieu, the maple(op(,)), as applicable, is more convenient at no risk.
It updates following the user command from upstream the project.
As well, it updates the the result that you may have spooled to file.
Visit Samples Beam Analysis few days ago.
#4 Posted : 28 March 2021 15:19:04(UTC)
... demo example.
Page3 Maple(op).sm (13kb) downloaded 30 time(s).
on 28/03/2021(UTC)
Offline churichuro
#5 Posted : 28 March 2021 17:58:34(UTC)
churichuro
Mexico
thanks fedeghi but...
Yes, I know, but only one division of the line is allowed, but "..."
in the form of an operator could be used as many times as you want
on the same line
currently if at the point you want to divide your expression is between parentheses "(" it won't work
try with this:
z:=(3+5-8*60-32) you can't
thank Jean, very good about maple and collect
operator "..." for this will be great!
#6 Posted : 28 March 2021 22:13:39(UTC)
Attach the complete document to try something.
