Originally Posted by: Jason McCool Any suggestions on how the text is displaying in controls? CheckBoxList Region fixed now. Please update it using Extensions Manager.
on 10/04/2021(UTC), on 10/04/2021(UTC)
Originally Posted by: overlord Actually one thing we really want is bold and italic font functions to work with linux. Sign-in option has secondary priority compared to this at the moment if you ask me. Yesterday I've spent some time on the issue regarding font style (bold/italic) in Linux and the only information I've found is this bug in Mono: https://github.com/mono/mono/issues/17314Tried to use suggested workaround, but it seems it is not applicable for us because of too slow performance. Here is a version of SMath Studio with my attempt to use workaround: http://smath.com/file/2wQhPIt works, but it is extremely slow - almost impossible to work with real worksheets. Will see, maybe another solution will be found in future. Best regards.
I will definitely try your solution. If it won't be applicable, so be it. After all this is drawback of mono. We accepted our fate. (swh) Regards Edit: Your solution works with fonts. But it has very slow performance indeed. Not "not usable" level but I won't prefer to use this daily. I will keep this version just for print purpose. Thanks Andrey. Edited by user 14 April 2021 04:55:01(UTC)
Originally Posted by: overlord We accepted our fate. (swh) I did it! Please download https://en.smath.com/file/UhVpV and replace SMath.Drawing.dll from the distribution package with downloaded one. Everything should work fast enough! Will include this workaround into the next build. Best regards.
on 15/04/2021(UTC), on 16/04/2021(UTC)
Originally Posted by: Andrey Ivashov Originally Posted by: overlord We accepted our fate. (swh) I did it! Please download https://en.smath.com/file/UhVpV and replace SMath.Drawing.dll from the distribution package with downloaded one. Everything should work fast enough! Will include this workaround into the next build. Best regards. Yes, it performs very fast just as "usual" builds. I have checked it only 2-3 minutes yet so far so good. Everything seems in order, well done.
