3 Pages<123
Online uni
#41 Posted : 17 September 2020 19:45:37(UTC)
uni
Example
Updated.
Changes:
- now a scalar is returned for a matrix with one element;
- example changed;
- small improvements.
Edited by user 06 November 2020 12:48:55(UTC)  | Reason: Not specified
Russia ☭ forever
Viacheslav N. Mezentsev
on 18/09/2020(UTC)
Offline Jason McCool
#42 Posted : 18 May 2021 18:30:27(UTC)
Jason McCool
United States
Was thanked: 9 time(s) in 7 post(s)
I don't know if this is the right place to post this, but I think the issue I'm seeing is with the SQLite plugin. I compose a query based on some user input via combo boxes, concatenate all the parts together into a string, and then use the SQLiteQuery function to query the AISC Table database. This normally works well. Now, I get an error indicating that a "\" symbol is interfering. The database file location has that symbol, but I don't think that is the issue. When I look at the resulting string in SMath, it looks like correct syntax. But when I copy it into DB Browser, it shows all of the spaces and single quote marks in the query string translated as \0020\ and \0027\ respectively. If I manually replace those in DB Browser, the query runs as anticipated. Is there any way to get that corrected? I'm using SMath version 0.99.7786.
Thanks,
Jason
Jason McCool
Robbins Engineering
Little Rock, AR, USA
Online uni
#43 Posted : 18 May 2021 19:47:04(UTC)
uni
SMath Studio compatibility
Plugin updated. Please try.
Changes:
- plug-in corrected to respect latest SMath Studio API changes.
Russia ☭ forever
on 18/05/2021(UTC),  on 18/05/2021(UTC)
#44 Posted : 18 May 2021 21:57:45(UTC)
Jason McCool
United States
Thank you! That worked great. You rock! Clap
Jason
Jason McCool
Robbins Engineering
3 Pages<123
