Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,650 Location: Italy Was thanked: 1337 time(s) in 878 post(s)
Hi, I found this bug defining user functions with IsString() The issue disappear using IsString inside line() regards, w3b5urf3r Edited by moderator 19 January 2016 16:44:41(UTC)
| Reason: edit for attach migration tests File Attachment(s): Davide Carpi attached the following image(s): |
Joined: 16/06/2012(UTC) Posts: 7 Location: Home Counties
regards,
w3b5urf3r I'm not sure whether this is a bug or a delayed-evaluation 'feature' of using/not-using the program line. I raised a similar question about a month ago ... Originally Posted by: Stuart Bruff Hello,
How is the equality (ctl-=) operator supposed to work? I get ([1]=1)=1 but ([1])=2; the latter I expect, but I am surprised that a matrix is equal to a scalar, even though it is just a single element matrix.
Is there a way of programmatically distinguishing between a scalar and an array? I know there's no IsScalar or IsArray function. I've seen the workaround for using num2str & mat and I've written a function
IsArray(x):= |n:=findstr(num2str(x),"mat" ) |n<>-1
(why doesn't IsArray(x):=findstr(num2str(x),"mat" )<>-1 work?)
, but this would appear to impose quite an evaluation overhead for large matrices. I was hoping to use x=stack(x) to check if x was an array, hence the purpose of my original question.
Stuart
Thank you! Fixed. Regards. Andrey Ivashov attached the following image(s):
on 30/07/2012(UTC), on 30/07/2012(UTC)
