Offline DiegoV
#1 Posted : 14 June 2022 07:52:42(UTC)
DiegoV
Costa Rica
Hi!
I have recently update Smath Studio to version 1.0.8151 and now I'm getting some errors on Draw2D() plot: See attached file. Ejemplo Maxima 2D Draw rectangles.sm (7kb) downloaded 22 time(s).
Apparently, now there is an error on labels, but in older versions of Smath it worked just fine.
The issue seems to be that now Draw2D() function doesn't support special characters and instead replaced them with UNICODE text...
Can anyone help me please!!?
#2 Posted : 14 June 2022 19:18:49(UTC)
This is due to a change in string encoding on SMath side. I haven't had time to adjust the string handling on Maxima side. I see two workarounds for now:
1. use an older version of SMath (I don't remember at which version the change was implemented).
2. add a custom translation rule in maxima.xml in the plugin directory. The procedure is described in section 7.6 of the SMath Handbuch (the section is in English).
You might try to replace "\\0020\\" by " ".
Note that custom changes to maxima.xml aren't conveyed with the .sm file, so this is not portable.
Offline DiegoV
#3 Posted : 15 June 2022 09:20:05(UTC)
DiegoV
Costa Rica
Make it native brute force.
The issue is with special characters like ".", " ", "_", "/", etc.
#4 Posted : 15 June 2022 16:48:23(UTC)
I confirm that there seems to be a problem with custom translations in maxima.xml. Sorry for guiding you into a dead end.
Possibly, this also has been broken at some version of SMath Studio. I'll ad that to the bug tracking system just as the string handling.
Online uni
#5 Posted : 15 June 2022 18:59:20(UTC)
uni
ConvertToMaxima.cs:
Code:
        public static string PrepareStringsForMaxima(string text)
       //     text = ConvertTrigonometricFunctionsFromSMathToMaxima(text);
            text = TermsConverter.DecodeText( text ).Replace("\"$", "");
            text = text.Replace("$\"", "");
            //foreach (var pair in CharactersToAscii) text = (new Regex(pair.Key).Replace(text, pair.Value));
            //foreach (var pair in letters) text = (new Regex(pair.Key).Replace(text, pair.Value));
            //foreach (var pair in symbolsToMaxima) text = (new Regex(pair.Key)).Replace(text, pair.Value);
            text = text.Replace("\\", "\\\\"); // convert backslash
            return text;
You need to add TermsConverter.DecodeText( text )
Edited by user 15 June 2022 19:03:17(UTC)  | Reason: Not specified
Russia ☭ forever
Viacheslav N. Mezentsev
on 15/06/2022(UTC)
Offline DiegoV
#6 Posted : 15 June 2022 21:50:50(UTC)
DiegoV
Costa Rica
ConvertToMaxima.cs:
Code:
            return text;
Hi Thanks!, but I'm not sure how to do that, can you guide me?
thanks 1 user thanked DiegoV for this useful post.
on 17/06/2022(UTC)
Online uni
#7 Posted : 16 June 2022 07:40:27(UTC)
uni
This is a hint for the plugin developer who needs to make changes to the source files in order to fix the problem: ConvertToMaxima.cs
Russia ☭ forever
#8 Posted : 16 June 2022 13:19:03(UTC)
Was thanked: 1339 time(s) in 878 post(s)
I've applied the fix proposed by Viacheslav, please try the updated plugin and check if it works.
on 17/06/2022(UTC),  on 17/06/2022(UTC)
#9 Posted : 17 June 2022 16:26:45(UTC)
Thanks, Viacheslav and Davide. I confirm that the fix works with version 8151. It is, however, not available for older version (tested with 7921).
EDIT: Tried again, works with 7921.
Edited by user 18 June 2022 00:18:33(UTC)  | Reason: Not specified
#10 Posted : 17 June 2022 20:18:59(UTC)
Hi Martin, thank you for the feedback, I wasn't able to test it myself.
I've published the current code for every stable SMath Studio since 0.99.7579, so it should be available in the extensions Manager for a wide user base.
Edited by user 18 June 2022 15:53:49(UTC)  | Reason: Fixed
Offline DiegoV
#11 Posted : 17 June 2022 22:48:07(UTC)
DiegoV
Costa Rica
It works! thanks!! ur the best!
#12 Posted : 18 June 2022 00:21:04(UTC)
Tried again, works now with 7921. Don't know what went wrong at the first try. Thanks again for fixing the problem.
