They talk about us
I really like it. It's one of the most usable free software applications I deal with.
more...
by Juanma Belda
Znakomite narzędzie, nie tylko dla studentów. Oby SMath rozwijał się nadal.
more...
by Witold P.
Fantastic free software. Have used it for several structural calculation reports
more...
by Martin Kynde
on 20/06/2022(UTC), on 20/06/2022(UTC), on 20/06/2022(UTC), on 20/06/2022(UTC), on 20/06/2022(UTC), on 23/06/2022(UTC)
Any case of "if" statement is available now. Approximately equal operator is available now (see Options dialog to set the accuracy):
on 20/06/2022(UTC), on 20/06/2022(UTC), on 20/06/2022(UTC), on 20/06/2022(UTC), on 20/06/2022(UTC), on 20/06/2022(UTC), on 20/06/2022(UTC), on 21/06/2022(UTC), on 22/06/2022(UTC)
Joined: 23/03/2016(UTC) Posts: 278 Was thanked: 91 time(s) in 57 post(s)
Hi Andrey,
I see the "Approximately equal" operator accuracy varies from 0 to 15. What does this value actually represent? |
Originally Posted by: alyles I see the "Approximately equal" operator accuracy varies from 0 to 15. What does this value actually represent? Hi! It is an accuracy of the "Approximately equal" operator. F.e. if the accuracy is 0, then pi≈3, if 1, then pi≈3.1, if accuracy is set as 2, then pi≈3.14 etc. Best regards.
Great to see Smath Studio is continuously improving!
Hi Andrey, considering that the "accuracy operator" parameter that regulates "approximately equal" is unique, wouldn't it be appropriate that it is defined in percentage terms?
It's more than just the decimal place precision. approximately.sm (5kb) downloaded 14 time(s). |
Originally Posted by: PompelmoTell Hi Andrey, considering that the "accuracy operator" parameter that regulates "approximately equal" is unique, wouldn't it be appropriate that it is defined in percentage terms? Regarding that.. I think "precision operator" more appropriately reflects the intended purpose. |
Originally Posted by: Andrey Ivashov Hi! It is an accuracy of the "Approximately equal" operator. F.e. if the accuracy is 0, then pi≈3, if 1, then pi≈3.1, if accuracy is set as 2, then pi≈3.14 etc.
Best regards. This is a nice new feature. Would it be possible to modify this value independent to regions? Adding another submenu to region right-click would be awesome. As in decimal places, exponential threshold, rounding choosing. Regards
Joined: 28/08/2014(UTC) Posts: 1,369 Was thanked: 829 time(s) in 525 post(s)
Hi. About the new approximately equal operator, another way to introduce it could be introducing a general infix operator, like in Mathcad. This screen capture is from Mathcad 6 running in Windows 3.11: For work with units you just need to modify the rhs by abs( a-b ) < UnitsOf( a-b )*TOL (or maybe UoM). Notice that also can be a solution for another features requests, like this one about inline division: https://en.smath.com/for...614_Inline-division.aspxAbout the "Defined Integral supports units now" it is a major improvement, and while there will be many worksheets to update, it is a substantial and very welcome improvement. I do think that some kind of special announcement should be made. Also, if you plan to also modify solve and roots to accept drives, you may want to introduce the two improvements together in a future stable beta release. Finally, many thanks to you Andrey and to all the developers who collaborate with the plugins for this excellent program. Best regards. Alvaro. Edited by user 22 June 2022 04:20:57(UTC)
They talk about us
excelente programita lo recomiendo
more...
by malandro
Great free software. I use it for calculations of civil structures. Thanks a lot.
more...
by Antonio Fazzutti
I use this program on my everyday civil engineering calculations, and I highly recommend it!
more...
by GiE
how to input else if? I use SMathStudioDesktop.1_0_8206.Mono
Originally Posted by: Jacques.chen how to input else if? I use SMathStudioDesktop.1_0_8206.Mono In the placeholders of the if() function type an "argument separator" symbol (comma or semicolon, usually) The if without else will improve alot the readability of many scripts, thank you Andrey. Edited by user 22 June 2022 13:54:44(UTC)
on 22/06/2022(UTC), on 27/06/2022(UTC)
Originally Posted by: Jean Giraud ~= I found no way to code double tilde Office 2000 in Win 7. Works fine as separate utility. Maths Round(U,n) UTILITIES.sm (15kb) downloaded 14 time(s). This is not the right place to post samples. Could any admin delete post above with mine? Regards
Перестали вычисляться безразмерные интегралы
Thank you. But the problem is not because of eval(). She's somewhere deeper. My f3(x) and f4(x) limits are ainterp() of the table data.
Originally Posted by: avp ... Thank you. But the problem is not because of eval(). She's somewhere deeper. My f3(x) and f4(x) limits are ainterp() of the table data. Hi. Yes, I see that there are more than one issue with the double integration, even for some simple cases it is not sowed. Best regards. Alvaro.
Originally Posted by: Jean Giraud You don't provide enough maths for attempting to doctor. You may get inspired from the double Simpson integrator. Please, don't hesitate ... Jean Double Integration Forum.sm (37kb) downloaded 9 time(s). The question is why in the stable version integrals are calculated without problems, but in the new one it gives an error in the same places?
Originally Posted by: Jean Giraud Originally Posted by: avp The question is why in the stable version integrals are calculated without problems, but in the new one it gives an error in the same places ? In other words, you declare a bug. Designers need the document for doctoring. ... doctor since which SS version ? 1.0.8151.26932 OK1.0.8206.25180 NFG Yes, I'm reporting a bug. In version 1.0.8151.26932, dimensionless integrals with limits in the form of arbitrary functions are calculated correctly. In version 1.0.8206.25180, such integrals are not evaluated. The error "x/y - undefined" is returned. Proizvol'noe sechenie.xlsx (14kb) downloaded 6 time(s). Proizvol'noe sechenie.sm (58kb) downloaded 6 time(s).Edited by user 05 July 2022 15:39:59(UTC)
Originally Posted by: Jean Giraud Originally Posted by: avp Yes, I'm reporting a bug. In version 1.0.8151.26932, dimensionless integrals with limits in the form of arbitrary functions are calculated correctly. In version 1.0.8206.25180, such integrals are not evaluated. The error "x/y - undefined" is returned.
It may be the XLS import ? Try NOT import as a stand alone system. It doesn't matter if there is an import from Excel or not. Proizvol'noe sechenie_no XLSX.sm (74kb) downloaded 12 time(s).
