SMath Studio Forum
Bugs & Problems
Bug in Smath Viewer using Special Functions
Joined: 28/02/2022(UTC) Posts: 21 Was thanked: 2 time(s) in 2 post(s)
Hi Guys, I found a bug after creating some EXE with Smath Viewer, to solve a specific function i use the bisection method. It work very well when i use the worksheet or the Smath Viewer Preview, but it don't work in the EXE. Someone can help me? The problem occurs in the function defined in the yellow zone. Maybe some one can reproduce the problem? Thanks DIMIS_224.sm (846kb) downloaded 21 time(s).
Joined: 23/03/2016(UTC) Posts: 278 Was thanked: 91 time(s) in 57 post(s)
I can at least confirm that I do not get the same results from the executable as I do with the worksheet. |
I get errors when I run the worksheet, further up. Might help to resolve those issues first. As a note you can see if you have errors by red marks in the side bar. I think there might be some hidden in collapsed areas as the errors don't seem to align with whats shown on the side bar. |
Originally Posted by: alyles I get errors when I run the worksheet, further up. Might help to resolve those issues first. As a note you can see if you have errors by red marks in the side bar. I think there might be some hidden in collapsed areas as the errors don't seem to align with whats shown on the side bar. Thank's for you reply! If you run the calculation one time this errors disappear, it's because i use some global variables! I figured one turn around, this worksheet is for design of many types of sections of reinforced concrete, the crack check using bending and normal forces is only carried for rectangular sections. The other types only check crack openings for bending. The initial example is a Tee Section, so the bisection method is not used, but if i change the inital example for a rectangular section, when i generate the exe it works.
SMath Studio Forum
Bugs & Problems
