Joined: 28/08/2014(UTC) Posts: 1,368 Was thanked: 828 time(s) in 525 post(s)
Originally Posted by: ioncube Hi. Notice that Refprop from NIST can't handle He/Xe mixing either. At least version 9. On the other hand, maple doesn't seem to implement the procedure that Viacheslav points out either, as can be seen in the online documentation for the latest version. However, very good values can be obtained using Coolprop in SMath and some basic stoichiometry. Mixing gases.sm (20kb) downloaded 16 time(s). Mixing gases.pdf (68kb) downloaded 17 time(s).Best regards. Alvaro.
Joined: 27/03/2019(UTC) Posts: 75 Location: coah Was thanked: 27 time(s) in 22 post(s)
is fantastic! this no work the first time but after I play with the another examples this work, very well thank you! Edited by user 30 April 2023 04:45:48(UTC)
Joined: 04/12/2017(UTC) Posts: 61 Was thanked: 2 time(s) in 2 post(s)
Uni, can you please help me how to add python into SMATH, I have python already in system [WinPython 3.9] How I link it up with Smath? I have working CoolProp
Jean, can you help me how do integrate python in my Smath? I event tried environmental variables under Win10 but didn't work
You should use a double slash for the full path. Originally Posted by: ioncube I event tried environmental variables under Win10 but didn't work In this case, you need to check whether python is available from the command line. If not, it means that the paths are specified incorrectly. Edited by user 31 July 2023 09:49:17(UTC)
uni, thanks a lot Can you tell me what is this block you used after python sub-section [i.e with the square bracket & holding script conetnts] Additionally Razonar sample here is also very intuitive while calculating mixing values https://en.smath.com/for...-of-state.aspx#post82120Edited by user 03 August 2023 01:19:12(UTC)
Originally Posted by: ioncube uni, thanks a lot Can you tell me what is this block you used after python sub-section [i.e with the square bracket & holding script conetnts] Mathcad Block from the Mathcad Toolbox plugin and just Text inside it for the script. Edited by user 03 August 2023 09:08:14(UTC)
uni, so it means the text inside the block is not automatically generated. Can you please explain the construct On second note you were correct, I fixed my environment variable under windows %python% now works Edited by user 04 August 2023 21:24:47(UTC)
Phase diagrams with CoolProps. PhaseDiagram.sm (40kb) downloaded 19 time(s).Best regards. Alvaro.
Psychrometric Chart with CoolProps. 'Simplified' version (more readable): Enthalpy lines overlap web bulb temperature lines. PsychrometricChart.sm (126kb) downloaded 20 time(s).Best regards. Alvaro.
I think I have found some problems while using plugin to get phase properties as discussed here: http://www.coolprop.org/...osing-the-phase-optionalFirst when using "P|phase_gas" it doesn't accept units & T,P values have to be directly written in SI equivalent Second there is a value discrepancy when using "P" & "P|phase_gas" for a fluid that exists only in gas phase at that T,P Worksheet1.sm (15kb) downloaded 6 time(s).
It seems that multiple instances of SMath can't use the plugin at the same time. How to reproduce: 1. Open SMath and access any Coolprop function 2. Open another SMath instance: You get an error message |
