Rank: Advanced Member Groups: Registered, Advanced Member Joined: 06/04/2023(UTC) Posts: 341 Was thanked: 26 time(s) in 25 post(s)
Simple in Mathcad with the return operator. Will be good to have it in SMath - see the attach NaCl-w-T.sm (15kb) downloaded 0 time(s).
Когда-то return был, насколько я помню, но потом его убрали. |
Originally Posted by: uni Когда-то return был, насколько я помню, но потом его убрали. Need return return!
Или так. |
Когда-то этот оператор был, но его убрали. |
Originally Posted by: OchkovVF Simple in Mathcad with the return operator. Will be good to have it in SMath
Joined: 11/01/2018(UTC) Posts: 134 Location: Wisconsin Was thanked: 62 time(s) in 39 post(s)
Greetings, Unstructured exits are best avoided when possible; there is merit in preventing unstructured exits. On that note, you may want to create your variable at the top of your function, assign it the value as desired, and 'return' it as the last line of your functions as such ('break' can be used to terminate a loop, which can be used to optimize runtime in lieu of a return). May this be of Good Help, - SK Kenny Lemens, P.E. ᵂᴵ |
