Rank: Advanced Member Groups: Registered, Advanced Member Joined: 06/04/2023(UTC) Posts: 338 Was thanked: 26 time(s) in 25 post(s)
It will be good!
Originally Posted by: OchkovVF It will be good ! We have it algo style... Lot more powerful/simpler, composed @ will. Cheers ... Jean. Maths algo ADVANCED.sm (16kb) downloaded 5 time(s).
Joined: 10/12/2009(UTC) Posts: 247 Location: Cali, Colombia Was thanked: 87 time(s) in 66 post(s)
Originally Posted by: OchkovVF It will be good!... Putting that block between quotation marks ("..." ) is a tricky option. That converts that block into a text or a "commentary" to your code. When you need that block to be evaluated, copy the text between the quotation marks and paste it into the code. Example: Now the block is a "commentary": Revert the process to enable evaluation Best, Oscar
