SMath Studio Forum
Bugs & Problems
Issues with embedded formula inside text region
MathWithinTextProblem.sm (5kb) downloaded 10 time(s).I am trying to use embedded formulas within the text region. When I define some variables within a text region and use them to perform some calculations within the same region, it works. But when I try to do the same calculation in a new text region, where the variables are defined earlier in a different text region, the formula does not work. Please find attached a minimum working example. This behavior is not expected. Is it a bug? Please help.
Originally Posted by: Chinmoy Kolay Is it a bug? Please help. Confirmed, probably this is a bug. When math region a=15 is disabled, text region calculations are not performed. When any variable of text region is calculated at math region, all calculations are done. Regards
Joined: 11/01/2018(UTC) Posts: 134 Location: Wisconsin Was thanked: 62 time(s) in 39 post(s)
Greetings,
Curious enough, it appears that if there is any mathematical evaluation in a math region above the afflicted Math-in-Text Region; it behaves as expected and produces a result.
Also, I am running appVersion(4) = "0.99.7822.147"; I don't think this is caused just by the latest release.
May this be of Good Help; ⚜ Kenny Lemens, P.E. ᵂᴵ |
SMath Studio Forum
Bugs & Problems
