Offline OchkovVF
#1 Posted : 28 May 2023 19:35:26(UTC)
OchkovVF
Was thanked: 26 time(s) in 25 post(s)
We need the i variable as variable but not as sqrt(-1)
Offline Kenny Lemens
#2 Posted : 30 May 2023 16:42:37(UTC)
Kenny Lemens
United States
Greetings,
There are other ASCII that can be used to avoid the imaginary number 'i'; For example, you can use the character below (will become Italic):
Code:
і:22
You also have the ability to use the 'i' variable with a subscript character (or a space) that will be treated as a different variable then 'i':
Code:
i.:22
May this be of Good Help;
⚜ Kenny Lemens, P.E. ᵂᴵ
thanks 1 user thanked Kenny Lemens for this useful post.
on 30/05/2023(UTC)
Offline OchkovVF
#3 Posted : 31 May 2023 15:14:48(UTC)
OchkovVF
Originally Posted by: Kenny Lemens Go to Quoted Post
Greetings,
Code:
i.:22
#4 Posted : 31 May 2023 16:30:43(UTC)
You can guess the drop from the vertical position of the scoping line of the cursor. You also can add a visual dot by typing i. Ctrl-K . This prevents the dot being converted to a comma . Yet, I am not a fan of any tricks which aren't obvious to the reader. But that is a matter of taste.
on 31/05/2023(UTC)
#5 Posted : 31 May 2023 20:24:36(UTC)
Your Tij make Trc ['r' row ... 'c' col]
on 31/05/2023(UTC)
#6 Posted : 01 June 2023 18:59:37(UTC)
That's what I meant. If the function generates complex
'i' could not be used as index.
#7 Posted : 02 June 2023 14:17:15(UTC)
Imaginary 'i' is pretty Universal, as such in Smath.
No need to freak as stupid as Mathematica 'ii'
[i,j] as compatible indices.
[r,c] ... [m,n] as otherwise needed.
Offline OchkovVF
#8 Posted : 02 June 2023 14:56:11(UTC)
OchkovVF
Must be so
#9 Posted : 02 June 2023 18:14:04(UTC)
A consistent way to define mathematical (and perhaps immutable) constants would be to mark them as units. In the case of e this would collide with the elementary charge but for i and pi this might work.
Yet this would require changes in the core of SMath, but part of the expected functionality could be provided by custom units.
There are some glitches in the dynamic assistant though:
- Original definition of i is displayed even though it is not available any more. This can be potentially dangerous
- Re-defined variable i is shown in the preview as we would like to see it in the sheet, yet in the sheet it is not italic.
imag.sm (28kb) downloaded 3 time(s).
Edited by user 02 June 2023 18:15:57(UTC)  | Reason: Not specified
#10 Posted : 02 June 2023 20:31:58(UTC)
Though, I don't vote for redefining 'i' in Smath,
how would it affect dependent plugins ? Polyroots, Matlab ...]
