SMath Studio Forum
Samples
Showing substitutions in a formula
Joined: 28/08/2014(UTC) Posts: 1,368 Was thanked: 829 time(s) in 525 post(s)
This function can be used to show the intermediate steps in the evaluation of simple formulas. Evals.pdf (112kb) downloaded 66 time(s). Evals.sm (48kb) downloaded 71 time(s).Best regards Alvaro.
3 users thanked Razonar for this useful post.
on 22/02/2023(UTC), on 22/02/2023(UTC), on 23/02/2023(UTC)
Joined: 11/01/2018(UTC) Posts: 134 Location: Wisconsin Was thanked: 62 time(s) in 39 post(s)
Greetings,
I just wanted to let people know that the Alvaro's 「Evals()」 function does not work numerically; it only works as a symbolic evaluation (ie., Optimization = ☑ Symbolic). As such, it cannot be used for numerical evaluations down the line.
Regardless of the limitations, I am quite impressed by this bit of handiwork.
- Kenny Lemens, P.E. ᵂᴵ |
1 user thanked Kenny Lemens for this useful post.
Hi Kenny, thanks. It is absolutely true, I completely forgot that the purpose is necessarily not only to show the calculation, but to use it later. Well, though, at least it's not a 3-order-of-magnitude error, like the one I recently had. This version saves in the first argument the numerical value of the evaluated formula. The rest of the code and the behavior stays the same. Evals v2.sm (66kb) downloaded 40 time(s). Evals v2.pdf (148kb) downloaded 19 time(s).Best regards. Alvaro. Edited by user 23 February 2023 01:19:42(UTC)
on 23/02/2023(UTC), on 27/02/2023(UTC)
Version with uncertainties calculations added. EvalsWithErr.sm (91kb) downloaded 35 time(s). EvalsWithErr.pdf (216kb) downloaded 14 time(s).Best regards. Alvaro.
on 30/03/2023(UTC), on 05/04/2023(UTC)
Joined: 02/04/2018(UTC) Posts: 135 Was thanked: 22 time(s) in 19 post(s)
Hi Alvaro, Great work with this. From an engineering calculation point of view, I think the additional intermediate steps are a little much. When checking a traditional SMath calculation, the biggest complaint is that the reviewer has to always flip back, or look back at the definitions of variables to see what values are being used in the given formula. Makes the checking process a bit tedious. What has always been missing from SMath was simply showing the substituted values as defined before the final result. (Only one step) As others have already posted, there are some tricks with optimization, but these quickly fall apart with units other than default units, and decimal values. Any way to modify your function to do something like this?: The function can of course be hidden in a table for a cleaner look. I also only showed the variable defined as an example. There would be no need to show this result again. I honestly think the black units in the calculations is great, as it helps separate defined units from calculated units. Would also be great to use definitions that are outside of the "Evals" function. This way variables can still be defined in one place, and values don't need to be re-entered. Let me know what you think.
Joined: 27/03/2019(UTC) Posts: 75 Location: coah Was thanked: 27 time(s) in 22 post(s)
1 user thanked churichuro for this useful post.
So I honestly think the original input was fine. Defining variables in a mathcad window is a bit annoying. The only change I think is needed, but seems to be very hard or impossible, it to define the variables, used in the formula, outside of the evals function. The best I can come up with requires you to define a second time what units are used for each variable used. As you can see the variables are defined as any other variable in a calculation sheet and can be used in other formulas. There is a vector that lists the units for each variable again. This is used to remove the unit when used in the Evals() function. It seems like there is no way to do this without manually specifying the unit because there is no way to convert the variable exactly as defined into a string, you need to divide out the unit to keep the same numerical value. So there is no way to take the b:=17.3 lb and convert that definition into a string exactly as I show it. It would be nice if this was automatic, but I don't this is possible with how SMath is programed. A note is that the first step in the substitution seems to reduce the units automatically. It would be nice to just show the initial substitution without any simplification or elimination of units in this first step. I also changed the way the final unit is shown, so that it matches the blue color of other units. Since in a table region you can display units in blue using "S:'" before the unit text. Evals v2-N.sm (29kb) downloaded 10 time(s).
Originally Posted by: wb.c ... Defining variables in a mathcad window is a bit annoying.... Hi. Yes, it is. But is the only way that I know to 'hold' an expression. Like in Mathematica Hold[x] or maple 'x'. I ask for that function here. Best regards. Alvaro.
SMath Studio Forum
Samples
