#1 Posted : 14 July 2023 12:07:53(UTC)
We tried to release an update of the Maxima plugin in the release manager.
There was no obvious hint on something going wrong.
Yet, when trying to access the new version from within SMath Studio, the installation fails.
The build log from the release manager shows some errors:
We observed that the directory name of the plugin has changed. Initially it was
SMath\extensions\plugins\44011c1e-5d0d-4533-8e68-e32b5badce41\1.98.8203.36407
When installing into an new sandbox (portable version) I get this:
\SMath 8348\extensions\plugins\f6052893-60c5-4ba7-a0b1-3f7ed33492d9\0.3.1.1595
So for now it seems that we spoiled the maxima plugin in the online gallery. Is there any way to roll back the changes and find out what was the problem?
#2 Posted : 14 July 2023 14:23:09(UTC)
You can delete anything published using the files manager (link in the homepage footer)
I suggest to search f6052893-60c5-4ba7-a0b1-3f7ed33492d9 in the sources (might be the guid of a dependancy?); solution and project files seems fine at first glance.
Edited by user 14 July 2023 14:37:09(UTC)  | Reason: Not specified
on 14/07/2023(UTC)
#3 Posted : 14 July 2023 14:44:01(UTC)
if you open the config file in the %appdata% folder, you get this:
Code:
0.3.1.1595
0
SharpVectors.Rendering.Gdi.dll
Offline fakemoses
#4 Posted : 14 July 2023 14:51:19(UTC)
fakemoses
Rank: Member
Was thanked: 15 time(s) in 7 post(s)
The "SharpVectors.Rendering.Gdi.dll" is a file in the /lib folder of the project. I am not sure how the config data manage to have that data in it instead of the MaximaPlugin.dll.
#5 Posted : 14 July 2023 15:00:53(UTC)
IDK, I don't see anything obvious from the changes in the project file. You have to ask Andrey, he can check the build process and find the cause.
#6 Posted : 14 July 2023 16:07:42(UTC)
Thanks, I deleted the new versions, installation should work now (tested with a portable version of build 8348).
on 15/07/2023(UTC)
