#1 Posted : 22 July 2023 17:44:10(UTC)
Was thanked: 1132 time(s) in 727 post(s)
The function DocumentDirectory() works fine when called at the canvas.
When called in a function body, then I get an error message, saying that the object pointer was not set to an object instance.
BTW, the GUI is set to english, SMath has been closed and re-opened. Still the error message is in german. Sorry for that.
fullname.sm (5kb) downloaded 10 time(s).
System information:
Offline Razonar
#2 Posted : 23 July 2023 03:08:08(UTC)
Razonar
Uruguay
Was thanked: 836 time(s) in 529 post(s)
The function DocumentDirectory() works fine when called at the canvas. ...
Hi Martin. The issue is because the line() statement. Without it DocumentDirectory() and other functions works fine.
As a workaround for the case that you need to use it with inside a line statement, and given that DocumentDirectory() just use the same argument "" always, you can save it into a constant, but could have others issues, like using that with include().
fullname.sm (5kb) downloaded 15 time(s).
