SMath Studio Forum
Samples
Unified Soil Classification System USCS
Joined: 19/08/2023(UTC) Posts: 3 Location: Cali Was thanked: 5 time(s) in 2 post(s)
Attached is a spreadsheet to classify the soil according to USCS and the granulometric curve is plotted by sieving. Please upload any improvements done to this file and post if any mistakes are found or if you have any suggestions. This is the original code. USCS1.sm (102kb) downloaded 15 time(s).This is the original code with another particle-size distribution USCS.sm (104kb) downloaded 9 time(s).Below in another post it is updated with a better presentation of the granulometric curve. Edited by user 07 September 2023 08:08:14(UTC)
3 users thanked Fav26 for this useful post.
on 01/09/2023(UTC), on 01/09/2023(UTC), on 01/09/2023(UTC)
Originally Posted by: Jean Giraud Thank you so much, I added the logistic sigmoid function you made to the initial code and it compare with and without the fit. In addition to the initial curve, I graphed it using the Zed Graph, where it can be better appreciated using a semilogx graph USCS-fit-Granulometry.sm (176kb) downloaded 12 time(s).Edited by user 07 September 2023 07:50:04(UTC)
Originally Posted by: Fav26 Thank you so much, Thanks as well, very educative. A large suite of math codes added Cheers ... Jean. Project USCS fit Granulometry.sm (91kb) downloaded 15 time(s).
SMath Studio Forum
Samples
