Rank: Advanced Member Groups: Registered, Advanced Member Joined: 06/04/2023(UTC) Posts: 348 Was thanked: 28 time(s) in 27 post(s)
Originally Posted by: OchkovVF See please the end of the attached file. Triplet roots ... FindRoot not doctored. 6-1-Mister-Class (1).sm (67kb) downloaded 3 time(s).
And the Lord God created the function eval and the lord said this is good! And the Lord God created the Maxima and the lord said this is sehr kompliziert! Edited by user 15 October 2023 04:00:33(UTC)
Hm, where exactly do you see the most severe сложности in the use of the Maxima plugin? Perhaps everything that needs a handbook is too complicated nowadays I really like the curve fitting interface with the Fit() function, which might even be comprehensible from the подсказка in the dynamic help. |
Joined: 28/08/2014(UTC) Posts: 1,368 Was thanked: 828 time(s) in 525 post(s)
Hi. Polynomial fitting, returning the same values that Excel returns. From this post. fit_CKO.sm (52kb) downloaded 5 time(s).Best regards. Alvaro.
Sorry! But the question was Why not How
Originally Posted by: OchkovVF Sorry! But the question was Why not How Hi Valery. Martin showed why. But for the quadratic case Máxima's Fit function does not return the same result as Excel, which could be said to have been taken as standard, since they are also the same as those usually obtained with the 'all powerful' (talking about of gods) a\b of Matlab. I made the post to show how those mythical values can also be obtained in SMath. Because SMath' solver isn't very powerful you can get those same values with your method using another, like the following one About the error vectorizing, you can see why taking a look of this Best regards. Alvaro.
Originally Posted by: Razonar Originally Posted by: OchkovVF Sorry! But the question was Why not How Hi Valery. Martin showed why. But for the quadratic case Máxima's Fit function does not return the same result as Excel, which could be said to have been taken as standard, since they are also the same as those usually obtained with the 'all powerful' (talking about of gods) a\b of Matlab. I made the post to show how those mythical values can also be obtained in SMath. Because SMath' solver isn't very powerful you can get those same values with your method using another, like the following one About the error vectorizing, you can see why taking a look of this Best regards. Alvaro. Send please sm-file!
There is not much sense in fitting functions with many degrees of freedom to data containing not much information. Any function which goes through the centroid of the data points will come up with a similar MSE. Is the second result really the best just because of it's lowest MSE? |
Valery, as it looks all doctored. Thanks Alvaro for the robust Broyden. Curious, Solver 30405 Slope/Intercept back on foot. 6-1-Mister-Class (1).sm (66kb) downloaded 1 time(s).
Wunderbar! Send me please the M matrix as sm-file!
Originally Posted by: OchkovVF Another way, from the same previous post . fit cars.sm (84kb) downloaded 8 time(s).Best regards. Alvaro.
Thanks! But the last plot must be so
Originally Posted by: OchkovVF Wunderbar! Send me please the M matrix as sm-file!
The data is from your website. I copy-pasted the table to a new text file and imported it. Just use the files provided in my post. As to the last plot: I guess the mileage limits of the individual lines are taken from the minimum and maximum slope observed in the age-mileage plot (fig.2 in your reference)? Do you see any particular problem or do you just want the work getting done? |
do you just want the work getting done? Yes ;-)
Global fit Cholesky Frequently, you can manage the Phi vector for a best regional fit. Project fit cars Cholesky.sm (20kb) downloaded 4 time(s).
