Online OchkovVF
#1 Posted : 06 November 2023 06:13:14(UTC)
OchkovVF
Was thanked: 28 time(s) in 27 post(s)
I have f(x, y) - thermal efficiency of a steam turbine with two steam extractions for heating feed water depending on the extraction pressures.
Question.
1. How to find the optimal pressure values at which the efficiency will be maximum?
2. Is it possible to build a surface? For now I have two separate 2D graphics.
More https://link.springer.co...0.1007/978-3-319-26674-9
2RegP-Ideal-new.sm (95kb) downloaded 13 time(s).
Edited by user 06 November 2023 06:21:22(UTC)  | Reason: Not specified
Online OchkovVF
#2 Posted : 06 November 2023 06:43:57(UTC)
OchkovVF
No, you cannot replace WaterSteamPro with Cool Prop for water/steam.
WaterSteamPro is a certified program!
Compare please two plots
Edited by user 07 November 2023 08:15:34(UTC)  | Reason: Not specified
#3 Posted : 07 November 2023 09:44:54(UTC)
I am not familiar with CoolProps but I think I could make a nice 3D plot with Maxima if you provide the smath file
on 07/11/2023(UTC)
Online OchkovVF
#4 Posted : 07 November 2023 19:10:43(UTC)
OchkovVF
Thanks, Martin!
Must be someone so
#5 Posted : 07 November 2023 20:53:03(UTC)
OK but I need a file where the wsp calls are replaced by coolprop ones. Even if plotting doesn't work as expected.
Online OchkovVF
#6 Posted : 08 November 2023 19:05:10(UTC)
OchkovVF
See please attach
2RegP-Ideal-Cool_Prop-95.sm (74kb) downloaded 17 time(s).
2RegP-Ideal-Cool_Prop-95.pdf (362kb) downloaded 10 time(s).
Martin (and all), I am waiting for the solution - 3D-plot and optimal values of p1 and p2.
#7 Posted : 09 November 2023 03:11:41(UTC)
Just the plot, no optimization yet.
2RegP-Ideal-Cool_Prop-95_Kr.sm (301kb) downloaded 16 time(s).
on 09/11/2023(UTC),  on 09/11/2023(UTC)
Online OchkovVF
#8 Posted : 09 November 2023 07:16:22(UTC)
OchkovVF
No optimization yet.
For checking
#9 Posted : 10 November 2023 00:31:08(UTC)
Agreed: CoolProp is CoolProp.
For quick visit, I use freeware Katmar IAPWS=97 in all sorts of units.
By same token, in Smath, we have lot of water/steam formulas.
What about you tabulate matrix style, then spline/interpolate.
I will be back on your document ... Jean
on 10/11/2023(UTC)
Online OchkovVF
#10 Posted : 10 November 2023 19:49:18(UTC)
OchkovVF
#11 Posted : 11 November 2023 07:40:46(UTC)
... confirmed vs my formula IAPWS-97
#12 Posted : 12 November 2023 08:37:31(UTC)
For checking
I get slightly different values. Still no automatic optimization because the objective function doesn't translate to Maxima. As a first step I made the function more robust by solving the two equations sequentially instead of simultaneously. In the original version sampling for the plot occasionally failed.
Plot MPa.pdf (220kb) downloaded 4 time(s).
2RegP-Ideal-Cool_Prop-95_Kr_detail.sm (158kb) downloaded 9 time(s).
2023-11-11 19_21_55-SMath Solver - [2RegP-Ideal-Cool_Prop-95_Kr_detail.sm_].png
2RegP-Ideal-Cool_Prop-95_Kr_detail.pdf (521kb) downloaded 7 time(s).
on 12/11/2023(UTC),  on 12/11/2023(UTC)
Online OchkovVF
#13 Posted : 12 November 2023 08:51:46(UTC)
OchkovVF
Wonderful!
But I dare to note that a real steam turbine unit has up to eight steam extractions from the turbine to regenerative heaters. And not only mixing, but also surface type.
Offline Razonar
#14 Posted : 12 November 2023 15:07:21(UTC)
Razonar
Uruguay
Was thanked: 829 time(s) in 525 post(s)
I get slightly different values. ...
Hi. Using the definition for partial derivatives and a pure numerical solver.
2RegP-Ideal-Cool_Prop-95_Kr_detail.sm (163kb) downloaded 10 time(s).
thanks 3 users thanked Razonar for this useful post.
on 12/11/2023(UTC),  on 12/11/2023(UTC),  on 13/11/2023(UTC)
Online OchkovVF
#15 Posted : 14 November 2023 08:13:59(UTC)
OchkovVF
