Offline Ale_Biaso
#1 Posted : 29 November 2023 13:02:54(UTC)
Ale_Biaso
Hi
I've got a problem with a 3D plot function.
The function is very simple but i'm not able to find the correct syntax for plot it.
Someone can kindly help me with some advising?
Thancks in advance, i attacched below the Smath reference file where i had higlighted with an arrow the function.
Cattura.PNG Azioni_Sismiche_Silo_D1101.sm (1,209kb) downloaded 7 time(s).
#2 Posted : 29 November 2023 14:26:12(UTC)
For instructions on Maxima plots see https://doi.org/10.25933/opus4-2949
Note that the dummy variables need to be undefined in the sheet.
Azioni_Sismiche_Silo_D1101_Kr.sm (1,232kb) downloaded 11 time(s).
Edited by user 29 November 2023 14:27:57(UTC)  | Reason: Not specified
Offline Ale_Biaso
#3 Posted : 30 November 2023 01:16:09(UTC)
Ale_Biaso
Thancks so much for your answer!!!!
I'm very gratefull!
#4 Posted : 30 November 2023 07:19:16(UTC)
Very easy to get the two circles ... one being shifted.
Tip about X_Y plot ... as soon as you open, give a title.
Next manipulation, click on title.
That technique will save from freaking X,Y ranges.
Jean.
#5 Posted : 01 December 2023 03:48:52(UTC)
The document from Martin does not work for me.
At this point of the project, if you can attach the matrix,
I may try to render the gray image in RGB.
I have the RGB mapping codes associated with the vectorise code.
Not so sure ... your matrix is huge 360 cols !
