Offline Saviind
#1 Posted : 26 November 2023 03:33:51(UTC)
Saviind
India
Hello All,
I have four unknowns in three linear equations. In this setup, can the FindRoot function get values for these variables?
I tried the same in MathCAD and could get the solution, but it is not working in Smath.
Can someone guide me, please?
Are there other possible solving methods for handling such equations with 6 or 8 unknowns?
Trial.sm (38kb) downloaded 12 time(s).[a Trial.sm (38kb) downloaded 12 time(s).ttach]48521[/attach] Trial.sm (38kb) downloaded 12 time(s).
Saviind
Offline overlord
#2 Posted : 26 November 2023 05:14:54(UTC)
Turkey
Was thanked: 509 time(s) in 339 post(s)
Usually al_nleqsolve() is more capable at this kind of situations.
Also your functions shouldn't have boolean operations.
#3 Posted : 26 November 2023 05:40:21(UTC)
Solve() from the Maxima plugin can handle under-determined systems of equations. In such cases, the solution contains a free variable. The name changes every time the sheet is recalculated. If you want to rely on that name, insert a MaximaControl("restart" ) command to reset the Maxima session and the counter.
Trial_Kr.sm (42kb) downloaded 8 time(s).
Offline Razonar
#4 Posted : 30 November 2023 08:08:00(UTC)
Razonar
Uruguay
Originally Posted by: Saviind Go to Quoted Post
... I tried the same in MathCAD and could get the solution, but it is not working in Smath....
Hi. Can you share the Mathcad result? This page is the help for matlab techniques for handling underdetermined systems: https://www.mathworks.co...r-equations.html#bt7ov7u
Writing the system as a linear one, SMath have some functions for work with those systems, like this one
Trial.sm (62kb) downloaded 7 time(s).
#5 Posted : 02 December 2023 01:40:17(UTC)
For your f(x,y,z) ... I get two sets of solved [x,y,z].
Smath solves the Mathsoft example, 4 unknowns.
Smath Butller is lot more advanced/difficult.
Jean.
Solve FindRoot f(x,y,z) ITERATIVE.sm (104kb) downloaded 10 time(s).
