Offline Giddyup
#1 Posted : 17 January 2024 14:04:13(UTC)
Giddyup
Rank: Member
I'm using the latest version of SM (1.1.8763).
I have auto-calculation enabled.
When I change a variable name, the functions referring to the changed/deleted variable do not show an error due to a missing variable. The functions keep the previous value until I move the function up in the page, to where it is forced to recalculate a different variable.
Selecting "recalculate page" does not help.
See video: recalculate
3DMsFHe.wmv (3,336kb) downloaded 6 time(s).
Edited by moderator 18 January 2024 03:20:47(UTC)  | Reason: video attached to the forum
#2 Posted : 18 January 2024 00:14:46(UTC)
If you attach the document, it might be possible to doctor.
#3 Posted : 18 January 2024 03:16:44(UTC)
Was thanked: 1339 time(s) in 878 post(s)
I cannot reproduce it in a simplified example, I guess there is something specific that triggers the behaviour shown in the video.
#4 Posted : 18 January 2024 05:32:45(UTC)
Your file is not an *.sm document.
#5 Posted : 18 January 2024 23:15:38(UTC)
The video attachment was added by me, since the original is uploaded to an external service and might be deleted.
Edited by user 18 January 2024 23:41:09(UTC)  | Reason: Not specified
Offline Giddyup
#6 Posted : 19 January 2024 11:12:17(UTC)
Giddyup
Rank: Member
recalculate.sm (12kb) downloaded 5 time(s).
I've attached a sample.
Instead of deleting the variable, I just clear it.
The last function (highlighted) keeps the old value despite the variable being cleared.
If I drag the clear() to the bottom of the page, the value of the second to last function (above the highlighted one) will not auto-calculate to remove the error. If I click "recalculate", it will remove the error.
If I drag the clear() back up, the second to last function immediately updates to show an error but the last function does not update to show an error.
If I drag the last function up, it will update to show an error.
#7 Posted : 20 January 2024 04:24:56(UTC)
Let me know if it works ... I had a crash on the other PC.
recalculate.sm (12kb) downloaded 1 time(s).
Offline overlord
#8 Posted : 20 January 2024 05:00:32(UTC)
Turkey
Was thanked: 509 time(s) in 339 post(s)
Aah, I get it now. This should be a bug.
While Clear(F.excitation) is enabled F.T can be calculated, obviously.
But when Clear(F.excitation) is disabled once F.T is calculated, F.T value remains.
Even there is no F.excitation because of Clear().
Changing all optimizations to symbolic doesn't matter too.
I will say it again, this should be a bug.
