Rank: Advanced Member Groups: Registered, Advanced Member Joined: 06/04/2023(UTC) Posts: 339 Was thanked: 26 time(s) in 25 post(s)
I want to solve three equations with three unknowns and display the solution on a 3D graph with two points - the roots of the equation. Help please!
Mathcad 15
Joined: 23/07/2013(UTC) Posts: 1,128 Was thanked: 509 time(s) in 339 post(s)
Findroot() or roots() could solve three unknown systems. About plotting, I simply wrote equations according to solving of z. Regards 3Dplot_OchkovVF.sm (5kb) downloaded 7 time(s).
2 users thanked overlord for this useful post.
on 21/02/2024(UTC), on 21/02/2024(UTC)
Joined: 15/04/2012(UTC) Posts: 1,987 Was thanked: 1124 time(s) in 721 post(s)
Is there a way to use CreateMesh() for single line xyz equations? x^2+y^2+z^2-2^2 creates a sphere in 3dplot, a finer mesh can look better. But I don't know how to convert an equation to CreateMesh(). I am asking if it is doable of course, if they are two different thing it is ok. A simple, short but inclusive tutorial would be beneficial.
Joined: 26/07/2022(UTC) Posts: 35 Location: UK Was thanked: 22 time(s) in 19 post(s)
Originally Posted by: overlord Is there a way to use CreateMesh() for single line xyz equations? x^2+y^2+z^2-2^2 creates a sphere in 3dplot, a finer mesh can look better. But I don't know how to convert an equation to CreateMesh(). I am asking if it is doable of course, if they are two different thing it is ok. A simple, short but inclusive tutorial would be beneficial. Like in the attached? (Though I confess it was a "suck it and see" approach as I don't fully understand the 3D graphing!) TriangleSpherePlaneCreateMesh.sm (7kb) downloaded 6 time(s).
Originally Posted by: StvMath Like in the attached? Not really, my question is different. You can make any object with CreateMesh(). You can make sphere, plane, cone, cube, etc with mesh. I ask for a method converting a xyz function to CreateMesh() matrix. If there is any of course. Regards
Hi Overlord. If you can isolate some of the x, y or z variables, you can use this. If not, Viacheslav develops a 3D implicit plot codes for mathcad, you can see that somewhere in the mathcad forum. create_mesh_xy.sm (9kb) downloaded 5 time(s).Best regards. Alvaro.
Originally Posted by: Razonar If not, Viacheslav develops a 3D implicit plot codes for mathcad, you can see that somewhere in the mathcad forum. The dots on the graphs above are a sign of my code being used. Originally Posted by: overlord I ask for a method converting a xyz function to CreateMesh() matrix. This is only possible for simple cases if the function is easily parameterizable. Edited by user 29 February 2024 22:52:29(UTC)
