1 user thanked Ber7 for this useful post.
Joined: 04/07/2010(UTC) Posts: 178 Was thanked: 19 time(s) in 13 post(s)
Ber7,
You amaze me with your use of graphics in SMath. I'm a civil engineer and use SMath for calculations just like this but without the pictures.
Could you post your SMath sheet in a zip file so I can see how you do it? I don't use RAR. Thanks. |
Ed |
Ber7,
Your animations and drawings always amaze me. Thanks. |
Ed |
Joined: 08/03/2012(UTC) Posts: 25 Location: Prague, Dolní Chabry Was thanked: 3 time(s) in 2 post(s)
Hello. This is very nice. I am civil ingenieer & I will use it. Thanks. However it is dangerous to use the function x>Lf. I found it out in my own beam programming. When changing direction of concetrated forces, the graph of shearing force has to jump once up & once down. And for the following input it does not!It seems to me, the function x>Lf does not work correctly each time. Regards Olik SMath files: beam 3 & 4.zipEdited by user 04 April 2012 02:16:30(UTC)
2 users thanked olik for this useful post.
on 04/04/2012(UTC), on 04/04/2012(UTC)
Olik, try to change x>Lf to eval(x>Lf).
2 users thanked kmihaylovich for this useful post.
Thank you, kmihaylovich, the file is corrected. Regards,Ber7
Thank you! This is already fixed and will work correctly even without eval function into the next SMath Studio release.
Regards.
Thanks to all. The eval function seems to be a good way. And if You fix this little bug, it will be the best.
Regards, Olik
Single moving load
2 users thanked Ber7 for this useful post.
on 15/01/2013(UTC), on 15/01/2013(UTC)
The load moves in deflection curve
Beam on elastic foundation.Movable load
Graphics with shading (http://en.smath.info/forum/resource.ashx?a=1691)
4 users thanked Ber7 for this useful post.
on 11/06/2013(UTC), on 11/06/2013(UTC), on 11/06/2013(UTC), on 13/06/2013(UTC)
on 13/06/2013(UTC), on 03/07/2013(UTC)
Beam with a variable distance between the supports
3 users thanked Ber7 for this useful post.
on 02/07/2013(UTC), on 03/07/2013(UTC), on 04/07/2013(UTC)
on 07/07/2013(UTC), on 07/07/2013(UTC)
Hello, could somebody help me. I don't understand how to solwe this problem.
